Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 10-18-2014, 06:19 PM   #1
1959 24' Tradewind
Excelsior , Minnesota
Valve or no valve
Hi,
After much searching I have decided to ask. Do I really need individual on/off valves to each appliance and do they go outside or inside and do they need an elbow or can I just use a flared copper fitting land bend copper when needed. Installing them seems to creat more opportunity for leaks and I could just turn the gas off from the tanks if I have problems. I'm trying to simplify.
Also any good books or sites for complete instruction would be appreciated.
Thanks!
Betsy
59as is offline   Reply With Quote
Old 10-18-2014, 06:27 PM   #2
1981 31' Excella II
New Market , Alabama
You don't really need them. I agree the potential for leaks is there when there is a valve.
Perry
Old 10-18-2014, 06:36 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
The furnace and stove come with one, so I used it. The fridge, water heater, and gas lamp do not have one. You have a master shut off on top of the propane tanks.
David
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 23 11-04-2022 06:48 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
OPD valve w/sight gauges 83Excella LP Gas, Piping, Tanks & Regulators 1 04-16-2002 07:21 AM
