Old 06-07-2016, 07:33 AM   #1
malinois38's Avatar
2008 28' International
Happy Valley , Pennsylvania
Using Airstream Propane Tanks For Generator?
I have a 2008 International that does NOT have the LP port. Just converted my Honda 2000 to tri-fuel and ready for our cross country trip. Not real interested in carrying more tanks than I have to (Have Tundra, Payload Challanged). I've read many threads on this topic, however everyone seems to carry propane tanks in tuck bed.
My question is this. Am I missing something or is there a reason that you cannot just run your propane converted generator off of your two Airstream tanks??
BTW, thanks to this site, my wife thinks I have totally lost it! Lol
malinois38 is online now   Reply With Quote
Old 06-07-2016, 07:40 AM   #2
WaLee's Avatar
Nevada City , California
Sure why not. Disconnect one tank from the trailer and use it for the gennie
WaLee is offline   Reply With Quote
Old 06-07-2016, 07:55 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
We run our tri-fuel generator off the LP port that is installed on our Airstream. You could either have a port installed (if you are not a DIY type, any qualified plumber can do this) or disconnect one of the tanks. I would think that disconnecting the LP tank on the Airstream to access it would be a PIA in the long run so I'd vote for installing the port.
Bob Martel
WBCCI# 5766
Old 06-07-2016, 08:45 AM   #4
Long Island , New York
Welcome to the forum!
The propane tanks are considered "high pressure" and the generator needs "low pressure" propane supplied. You can tap into the propane supply lines downstream from the OEM AS regulator. You will need to add a regulator if you connect directly to the AS tanks.
The OEM port on newer AS's is already low pressure. Our new Yamaha 1000 tri-fuel gen also came with a regulator to use with standard high pressure BBQ tanks, and the AS has an adaptor hose to connect the gen to the trailer's port (without BBQ regulator) or to connect a BBQ grill to the trailer.
The following link gives details about our Yamaha 1000 and other similar units of different sizes.
http://www.airforums.com/forums/f448...ay-150492.html
Good luck!
Peter
PS 1000 vs. 2000:
http://www.airforums.com/forums/f448...0i-147804.html
Old 06-07-2016, 08:52 AM   #5
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up Works for us....
Just as easy....pankake stores in the Classic's 'trunk'.
Name:	LIQUID STAINLESS STEEL 281.jpg
PFC
but Im the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-07-2016, 11:29 AM   #6
Did you buy that long extension hose online, or did you make it up yourself? Thanks
Old 06-07-2016, 11:51 AM   #7
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
We got the kits from Genconnex for our pair of Honda 2000s. We got 3 hoses with the kits.
Two of them are meant to connect directly from the LP tanks to the generators. They have a regulator built in to the hose (low vs high pressure was mentioned earlier). Note the tank threaded fitting on one end and the 3/8" female quick disconnect fitting on the other. The Genconnex kit has a 3/8" male QD fitting on the generator.
We got one of these with each generator:
Name:	ImageUploadedByAirstream Forums1465317723.663319.jpg
Also, I FINALLY got my Weber Q120 converted as well and had the Torjik folks ( http://torjik.com/#_convertaq ) create a custom hose to connect to a 3/8" fitting as well. So I can use this hose to run the Weber from my AS LP tanks or a 20# tank away from the AS (like at home). These hoses also allow me to run the generator from home off a 20# tank should that be needed.
Genconnex also custom-made a 3rd hose for me to connect from the RV port (1/4" quick disconnect) to a T fitting that splits off to feed the pair of connected generators with a 3/8" fitting. Each hose input to the generator has its own on/off valve so in theory I could run one generator off the RV port and close the other line, or even run the grill off the other line.
Name:	ImageUploadedByAirstream Forums1465318032.768519.jpg
You can definitely do either/both if you like.
SteveSueMac is online now   Reply With Quote
Old 06-07-2016, 12:35 PM   #8
Thumbs up
I purchased the entire kit from US Carb in 2007, Spring 2008 inst., quick-disconnect at both ends of the hose. Still running strong LPG/gas.
PFC
RLC
Old 06-07-2016, 02:21 PM   #9
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
How much propane do generators (lets say a Honda 2000) use? Are they pretty efficient or do they deplete a tank pretty quick?
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 06-07-2016, 02:58 PM   #10
Chelsea , Michigan
Images: 12
A good rule of thumb is that it will use LP at about the same rate (i.e., gallons) as gasoline. In other words, if you would have used 1/2 gallon of gasoline to run your generator for 4 hours you will use about 1/2 gallon of propane for the same amount of generator usage.
The relative energy in a gallon of gasoline is somewhat higher than a gallon of propane so I am sure that some "purist" will point out that your LP usage will be somewhat higher than had you been using gasoline, but in the "real world" you will hardly notice the difference.
I have a 2000 watt Yamaha and as I recall, when I was breaking it in on on gasoline with a small load (as recommended by the manufacturer of the conversion kit,) one gallon of gasoline lasted nearly seven hours. I have not measured the efficiency on LP as that is hard to do, but I'm willing to operate under the assumption that it's close enough to the same.
Bob Martel
WBCCI# 5766
Old 06-07-2016, 03:44 PM   #11
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
It is easy to install a port.
I put mine where the flexible hose from the regulator connects to the copper line under the coupler A-frame. You will need a quick disconnect fitting pair available from Amazon and others, a T fitting, and some (probably four) adapters, all available from a home improvement store. There is a propane fitting between the hose and the pipe. Take it out. The fitting on the hose and the fitting on the pipe are two different sizes. Measure them to be sure to get the right size. In my case the larger one screwed right into the T fitting. I needed a reducing bushing for the smaller mate for the hose fitting. A close nipple is needed to connect the female part (with the shutoff) of the quick disconnect to the T. A roll of propane-rated teflon tape or pipe dope and you are good to go. I'd send a picture but the trailer is in storage.
I mostly use it for my grill, but I have the same fitting on my generator (which I just converted).
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-07-2016, 04:49 PM   #12
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
@ AnnArborBob...thanks. Beats carrying around gasoline.
Old 06-07-2016, 06:10 PM   #13
Originally Posted by Al and Missy View Post
...The fitting on the hose and the fitting on the pipe are two different sizes. Measure them to be sure to get the right size. In my case the larger one screwed right into the T fitting.....
Al
What I meant to say was the adapter that mates with the larger one screwed right into the T.
Al
S/OS #004
Old 06-07-2016, 07:56 PM   #14
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Be careful where you connect to propane. US Carburation uses two regulators to reduce pressure down to the genny. The input/ output to the genny is higher that your normal Airstream 11" wc pressure and volume. If you draw more volume than the Airstream two stage regulator can supply, the regulator will freeze and starve the genny. Your genny output will be limited. You need to call US Carb and ask them if the set up you are attempting to use will handle your genny needs. It depends on the size of the generator. I had to connect mine directly to the bottles. For 2 bottles, I use 2 "Y" connectors, 2 pigtails, a 3-way ball valve, and a 3/8" quick connect after the first regulator. That way you can use low pressure hoses to run to the genny(s). I got my hose and quick connects from US Carb. It is a handy set up not having to disconnect and connect Acme connections every time you fire up the genny.
guskmg
guskmg is online now   Reply With Quote
Honda EU2000i Generator - using with Airstream DHart Electrical - Systems, Generators, Batteries & Solar 74 04-21-2015 11:20 AM
Grey and black tanks using the same vent pipe Bowmans Waste Systems, Tanks & Totes 6 04-12-2015 11:29 AM
Heat -- using propane stove top burners or oven Jim Lee On The Road... 25 01-24-2014 06:12 AM
Anyone using these? Regascoe's Clear View LP Tanks? Phrunes LP Gas, Piping, Tanks & Regulators 2 06-15-2013 07:46 AM
Views on using Simpson Strong-Ties as Hangars for Tanks DanielB Repairing/Replacing Floor &/or Frame 5 01-08-2011 12:46 PM
