Old 06-07-2016, 08:43 PM   #15
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We don't have an Airstream supplied port on our trailer so I plan to run my tri-fuel Yamaha 2000 watt generator off one of the 30 lb tanks if necessary. For now I do have an extension hose that I got from US Carburetor that has a regulator on it so I will be coming off the tank's high pressure POL valve.
I plan to put on a tee that will screw into the tank with an end that will allow the Airstream's POL connection to connect. There will also be a 3rd capped output that will allow me to tie to the generator if needed. That way I won't have to disconnect the POL connection to the trailer.
Here's a link that can help on estimating propane usage and run time. http://www.motorsnorkel.com/propane-...-rate?___SID=U
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-07-2016, 10:02 PM   #16
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Not the greatest pic, but here's where I tee'd in my quick connect ( just on the downside of the propane regulator, under the tanks) to be able to use the onboard propane and not have to haul extra tanks along with us.
I also installed the GenConnex kit in my new Honda. For the tee, I ordered some spare parts from GenConnex and got the rest from Ace hardware.
When we're ready to hook up the generator we simply quick connect each end & open the ball valve!
truxpin is offline   Reply With Quote
Old 06-07-2016, 10:31 PM   #17
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
I have been reading several types of LP discussion for generators. May I know why you would want to convert to LP since filling it would seem more work than gasoline?
cazual6 is offline   Reply With Quote
Old 06-07-2016, 11:07 PM   #18
jcanavera's Avatar
Fenton , Missouri
Images: 143
Using Airstream Propane Tanks For Generator?
First carrying gas cans in your vehicle has more risk that propane. Gasoline deteriorates with time. Propane does not. Propane burns cleaner than gas. No carburetor fouling. Your generator will have a longer life span. Your trailer has a readily available supply of propane. Exhaust gases from a propane engine are cleaner. No ethanol to attract moisture in the tank. Engine oil stays cleaner. A gallon of propane gives almost equal run time as a gallon of gasoline.
To me the biggest down side is the fact that propane gas production minimizes when temps get really cold. That's why I bought a tri-fuel model so that I can run on natural gas at home if we have a winter power emergency.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-08-2016, 12:13 AM   #19
Stay CazuaL
cazual6's Avatar
Reseda , California
Jack
Good info. I've consider it a while ago when I was informed about storage. Since I don't store my gas longer than three months before use, I figured no need to convert. Your suggestion of running cleaner is the most appealing, the other benefits can be argued, all good points and have pros and cons in their own right. I appreciate the info. Now to ponder.......
Old 06-08-2016, 02:20 AM   #20
Long Island , New York
The elimination of all gasoline inside the tow vehicle and/or trailer storage areas makes this choice a no-brainer IMO. Never have to fill a gas can, especially while camping and then running out in the car when low.
Once the proper hoses and connectors are purchased, the propane generarator is actually less work and simpler, again . . . IMO.
Old 06-08-2016, 11:52 PM   #21
Stay CazuaL
cazual6's Avatar
Reseda , California
I have a 2014 Cloud, there is a port on the front, is that considered low pressure for the use of a generator if I convert? Any info on converting yaMaha 2000i would be appreciated.
Old 06-09-2016, 04:43 PM   #22
Welcome to the forum! Yes, that port is available for a generator, BBQ etc. I will post links for your consideration next.
The user jcanavera has been reporting on the following thread about his new Yamaha 2000:
http://www.airforums.com/forums/f448...ay-150492.html
You could also peruse the list of the topics in the sub-forum, of which this thread is a part [see hierarchy above left in blue labels between ">" symbols]:
http://www.airforums.com/forums/f287/
1000 vs. 2000: http://www.airforums.com/forums/f448...0i-147804.html
Conversion generally: http://www.airforums.com/forums/f448...ne-148661.html
Yamaha 2000 conversion retailer: http://www.yamaha-propane-natural-ga...m/ef2000is.htm
I just got a 1000 from this company, as reported on this thread.
Yamaha mfg. comparison 1000 vs. 2000:
https://www.yamahamotorsports.com/ge...20091d7ca01773
Generators and solar power sub-forum:
http://www.airforums.com/forums/f448/
That should be enough reading for the night!
Good luck,
Peter
Old 06-09-2016, 11:26 PM   #23
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Thanks to everyone for their comments, feedback and educating me so well. I have learned a lot on this thread and
http://www.airforums.com/forums/f448...ml#post1804456
CruizinDux is offline   Reply With Quote
Old 06-10-2016, 01:39 AM   #24
Stay CazuaL
cazual6's Avatar
Reseda , California
Thumbs up
Good luck,
Peter
you're alright!!
Old 06-19-2016, 06:57 AM   #25
On a recent trip (reported on the 20-footer thread), FYI we had the benefit of this 10' extension hose for the propane, but could have used another 10' length, in order to be able to put the Yamaha 1000 generator anywhere on the site for maximum quiet. I put the generator in the back of the van, facing the back of our site, and put moving pads loosely around it to muffle the sound. It worked out great, but being able to back the van up another 10' would have helped a lot.
This hose comes complete with quick connect ends, and the female end has its own shut-off valve. It does take a while for the propane to fill the hose, but priming the gen helps accomplish this. Will try putting a spare male quick connect fitting in the end of the hose, and bleeding the low-pressure propane manually out the end. TBD
Old 07-28-2016, 01:53 AM   #26
TinVenture's Avatar
2016 19' International
Orange County , California
Originally Posted by SteveSueMac View Post
We got the kits from Genconnex for our pair of Honda 2000s. We got 3 hoses with the kits.
Two of them are meant to connect directly from the LP tanks to the generators. They have a regulator built in to the hose (low vs high pressure was mentioned earlier). Note the tank threaded fitting on one end and the 3/8" female quick disconnect fitting on the other. The Genconnex kit has a 3/8" male QD fitting on the generator.
We recently took delivery of a 2016 19' Signature which came with the LP connector at the front. I purchased a Yamaha EF3000ISEB generator with the US Carburetor Tri-Fuel kit. I have a hose which has a regulator attached so it can be hooked up directly to a propane tank. I want to ditch that hose and use a quick disconnect hose to connect directly my generator to the LP port. If I understand correctly, the AS has a 1/4 female fitting and I need to install a 3/8 male fitting on my generator?
I thought propane tanks and generators use 3/8 fittings. I want to make this as easy as possible to quickly attach and remove a hose from the bed of my picked to the AS without any tools.
This forum has been a wealth of knowledge and I appreciate all those who contribute their time. I had no idea what we were getting into but couldn't be happier!
TinVenture is offline   Reply With Quote
Old 07-28-2016, 05:34 AM   #27
I replied in the other thread:
http://www.airforums.com/forums/f287...ng-104363.html
Good luck!
Peter
Honda EU2000i Generator - using with Airstream DHart Electrical - Systems, Generators, Batteries & Solar 74 04-21-2015 11:20 AM
Grey and black tanks using the same vent pipe Bowmans Waste Systems, Tanks & Totes 6 04-12-2015 11:29 AM
Heat -- using propane stove top burners or oven Jim Lee On The Road... 25 01-24-2014 06:12 AM
Anyone using these? Regascoe's Clear View LP Tanks? Phrunes LP Gas, Piping, Tanks & Regulators 2 06-15-2013 07:46 AM
Views on using Simpson Strong-Ties as Hangars for Tanks DanielB Repairing/Replacing Floor &/or Frame 5 01-08-2011 12:46 PM
