Old 02-25-2006, 07:33 PM   #1
1976 31' Sovereign
1963 16' Bambi
1971 21' Globetrotter
Marbletown , New York
Up-dating Tanks
I have 2 aluminum tanks that need to be updated. They were the originals from my 1976, 31' Soverign. I can't find anyone in my area that will do the work, (3 LP distributers, and one large camper outlet). Does anyone have any suggestions? I'm in the Kingston New York area and will take them to the nearest place someone can suggest. Thank's
Stone Ridge is offline   Reply With Quote
Old 02-25-2006, 07:52 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Hi DHunter,
Welcome to the forums!
I had one set redone at a welding gas place. IIRC it was National Welders. The other set was done at an independant gas/oil dealer that is no longer in business. For the independant I had to order the valves, but they did the cerification and installed the valves for me.
Aaron
WBCCI #XXXX AIR #2495
Old 02-25-2006, 08:53 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Up-dateing Tanks
Greetings DHunter!
Welcome to the Forums!
I am not familiar with your region of the country, but if you happen to have an Airstream dealer in your region who is Vintage friendly, they may be your best source for assistance. When I had trouble locating a vendor willing to re-certify my '78 Minuet's Worthington tanks, Ace Fogdall RV was able to handle the new valves/re-certification as part of my annual maintenance/service visit.
Good luck in your search!
Kevin
Kevin D. Allen
AIR #827
Old 02-26-2006, 06:06 AM   #4
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
ReCert
You might call Colonial Airstream, 732-367-4499, 1121 RT. 88, Lakewood, NJ. 08701 / www.colonialairstream.com
Don
Gunnyusmc is offline   Reply With Quote
Old 02-26-2006, 05:08 PM   #5
1976 31' Sovereign
1963 16' Bambi
Thank you all. I'll let you know how I do (did?)
DHunter
Old 02-26-2006, 09:30 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have 2 30 pounders that have not been updated, they are steel. One ran out this weekend and it seems like a good time to upgrade to aluminum tanks. where can I get the best price???
Richard
Old 02-27-2006, 09:40 PM   #7
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Do a forum search for Worthington tanks. Best I remember, Vintage Trailer Supply had the best prices.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-28-2006, 07:22 PM   #8
JimGolden's Avatar
1977 31' Excella 500
OPD Valves?
By update, do you mean replace the old valves with the newer OPD valves? I replaced the valves in two 20lb tanks for my Weber gas grill. I got the valves online and then installed them myself. It wasn't easy getting the old ones out; they're torqued in there pretty tightly and it's hard to hold the bottles still, but I chucked a steel rod into a vise and then slid the tank shield holes through this rod and turned the valve with a large wrench with extension bar. I had to basically turn the valve a partial turn, then pull the tank off the rod and put it on 180 from how it was before and then wrench the valve some more. Took several iterations of this before the valve was loose enough to keep the tank "chucked" in one place and get the old one out. I then just cleaned up the threads and put the new valves in using thread tape. Took them to the LP place, filled them up, then weighed them on a digital bathroom scale certified to the tenth of a pound. Waited two weeks and then weighed them again. They were identical. Did the soapy water test around the top, no bubbles. Been fine for three years now.
- Jim
JimGolden is offline   Reply With Quote
Old 02-28-2006, 07:43 PM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
Yes, they lack the OPD valve. I could upgrade the ones I have, but I want to go with the aluminum tanks. More to polish!
Richard
Old 03-01-2006, 08:34 AM   #10
JimGolden's Avatar
AL all the way!
I hear you on that one. Two new 40lbers are in my near future too. Gotta shine
- Jim
Old 03-01-2006, 12:39 PM   #11
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Try here, azflycaster
Oasis RV in Tucson.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-02-2006, 05:55 PM   #12
1976 25' Caravanner
Campton , New Hampshire
I had mine done by a local gas distributer . They had to order the valves , when they came in I brought the tanks in and they changed the valves , filled the tanks , and recertified, total $92.00.As someone said before , try a gas company that handles all types of gas , i.e. , welding , medical , propane , they might be more willing . Airstream dealers in NY ,Paterson 914-898-9400 , Harpersville , 607-693-4295 . Good luck
ticki2 is offline   Reply With Quote
Old 03-04-2006, 08:51 AM   #13
1976 25' Caravanner
DHunter , another lead for you . F.W.Webb is a large pluming supply house . They are also distributors of Worthington Tanks , they can probably get you the OPD valves and possibly recertify . There's one in Albany and one in Queensbury . Hope this helps
Old 03-04-2006, 08:56 AM   #14
1975 29' Ambassador
Reno , Nevada
Do check to make sure that you get new valves with the proper dip tube length. This is sometimes stamped on the tank colar "DT=xx" - some propane folks don't check too carefully and install the wrong valves. Aluminum tanks are taller than steel of same capacity so have longer DT length valves.
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
Another reason for aluminum tanks rochleau Our Community 4 09-03-2002 06:30 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
