Old 01-25-2007, 08:31 AM   #1
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Underfloor Water Tank
I'm working on my 56 caravanner and one of the things I would like to do is maximize the interior space up front, but guess what the darn water tank is in the way
Has anyone discussed the idea of putting the fresh water in the frame? I was thinking of a small tank 13-15 gallons that could be custom made to fit into the 4" x 48"x36" area held up by strong straps. The tank would have to be tappered to flow the water down to the outlet but that might be an option. The inlet and vents would likely have to come into the rig and out the side as needed.
Anyone done this type of thing?
Doug
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 01-25-2007, 08:37 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
SmokelessJoe has radically altered the tanks on his Argosy -- plus other ideas to numerous to mention. Here and here.
See any answers in there?
5 meter Langford Nahanni
Old 01-25-2007, 08:47 AM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Doug
Yes. The Airstream Factory, from 1969 to present.
Seriously, I'm sure this design would be quite adaptable to vintage units. I think this is in "Safari Tim's" plan for his ambassador.
70's units had a custom tank made to take up 2 frame cavities, so there's a generous 45gallon capacity. I'm sure you could accomplish the same thing using 2 seperate tanks...or if ~20g is enough, just one. You can also rig it w/ the plumbing so that it fills from the city connection, although, if that's the only method, you'd lose the ability to fill it w/ a bucket. (and I've done that, in a pinch).
Put the drain along the back edge, then the tongue jack will give you all the slope you need.
the 70's tanks were (are) flat. and it does take a long time to drain on mine, anyway...the drain is only a 3/8ths pipe. it can take a couple of hours to empty it.
Since you're going to be doing frame mods, I'd say you could probably even get one of these specific tanks...but they're meant for a 5" cavity.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 01-25-2007, 08:56 AM   #4
1956 22' Caravanner
Frame
Here's a picture of my frame, already modified. In the picure starting at the bottom, the grey water tank goes in the first bay. The next one or two I was thinking of using for water. The large area up front is for a spare tire that Colin and company are fashioning for me.
The tire carrier will stick down a couple of inches but I wanted the rest to be flush, so the tanks would be limited to 4". IN the 70s plan how do you fill up the tanks? Is there an inlet on the side?
Old 01-25-2007, 09:29 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yup. like the gas tank on your car....
pipe comes inside, hidden by the galley cabinet. stays above the floor of the cabinet as it comes in toward the frame rail, then goes down into a big hole in the floor that forms a compartment of sorts, so you can access the connections to the tank. (fill, drain, pump intake lines, h/c water supply drains). The tank/water connection access hole is still inside a cabinet, so its not visible from the living area.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 01-25-2007, 11:44 AM   #6
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
If the photos upload, here is how my '72 GT has it plumbed. Street side.
Dave
ID:	31301   Click image for larger version
Fyrzowt is offline   Reply With Quote
Old 01-25-2007, 12:02 PM   #7
1956 22' Caravanner
neat
Dave
And that was original? very cool. Gives me a couple ideas.
Old 01-25-2007, 12:07 PM   #8
Fyrzowt's Avatar
Images: 8
Original as far as I can tell. Let me know if I can help, photos are easy to get - weather is nice.
Old 01-25-2007, 02:00 PM   #9
Jacob D.'s Avatar
1964 26' Overlander
Alameda , California
I'm working on this same project for mine, putting all three tanks under the floor between the rails. The black tank was there originally, but quite small. I'm thinking I will go below the frame with the fresh & grey water tanks because they'll be close to the axles.
Jacob D. is offline   Reply With Quote
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
