Old 03-07-2010, 06:01 PM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Exclamation Under trailer propane lines
While under the Trade Wind, I noticed that the propane lines have a couple issues. First, at the front end where it goes under the camper from the tanks, the line has been compressed. Everything works and I don't know if this is a safety issue or not. Second, one of the Junctions between two pieces is the wrong kind and needs repaired for sure.
I have to move the line some to install the new Bal stabilizers, so I am wondering if the smart money isn't to completely replace the main line.
If the answer to that is yes, what size tubing and of what type should I get? What is the best way to protect them against road rash in the future? Oh yeah, what is the proper size line coming off the main line to individual appliances?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-07-2010, 08:02 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
I am surprised people are being timid about weighing in on this one.
Rodney
and the
My Blog
Old 03-07-2010, 08:08 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Rodney,
On my Liner, I used 1/2" type L soft (under slab) copper for the main line. No branches since all appliances are on the same side. Up through the floor with the supply for the appliance. I used pipe insulation for protection of the soft copper.
Hope this helps.
Bill
Just my personal opinion
Old 03-07-2010, 08:38 PM   #4
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
On my 75 TW the main line is 5/8" and the branches are 3/8". I do not have any protection on my lines and they have held up well for 35 years. I also do not travel as many forest roads as you do.
Richard
Old 03-07-2010, 08:42 PM   #5
cameront120's Avatar
1972 25' Tradewind
To protect the lines, you can use rubber garden hose in a diameter to fit over the tubing. Cut it along its length in a spiral fashion (helps prevent the hose from working its way off the propane line) and fit it over the propane line.
North Vancouver, BC
Old 03-07-2010, 09:26 PM   #6
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by wkerfoot View Post
Rodney,
Hope this helps.
Bill
Protecting the copper gas line is a bad idea. If there is a leak, it will help pool the gas.
Michelle TAC MT-0
Sarah, Snowball
Old 03-07-2010, 09:31 PM   #7
1972 25' Tradewind
Aren't we talking about protecting the lines that are on the underside of the coach?
North Vancouver, BC
Old 03-07-2010, 09:36 PM   #8
Keymar , Maryland
Yes and that is why they are under the coach. If they leak the gas dispurses. It is also bare so you can inspect them for corrision.
Michelle TAC MT-0
Sarah, Snowball
Old 03-07-2010, 09:37 PM   #9
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I realize that I have an accountants mind, but I am not sure where the gas would pool in a 1/2" pipe insulation. I am sure that you could put the split to the bottom and since propane is heavier than air, it would settle out into the atmosphere. My 1979 Safari has something similar to the pipe insulation. In addition, the insulation gives one something to attach the straps holding the line against the belly pan without the possibility of chaffing.
Bill
Old 03-07-2010, 09:57 PM   #10
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
in 24yrs I've never had a problem with uncovered lines.
Just something else to remove for inspection.
Be aware that there is always the possibility of damaging a line and not being able to see it because of a garden hoser...
PFC
but Iím the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-07-2010, 10:09 PM   #11
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
I just finished replacing the lines on the Bambi today. I used half inch copper for the main and three eights for the three branches. Under the trailer I slid plastic ( the black stuff with the split along its length, used for wrapping electical wires) it looks great and it protects with no danger of gas buildup.
Tim
Beaker63 is offline   Reply With Quote
Old 03-08-2010, 01:57 AM   #12
Maniacal Engineer
barts's Avatar
Menlo Park , California
Our Tradewind's lines are also somewhat crimped along the underside of the tongue; clearly someone put a jack or jack stand under there at one point.
That's one spot that could use a little protection. or the copper pipe run along the inside face of the tongue rather than the bottom.
One nice way of protecting the line would be to cut some 1 & 1/4" pipe lengthwise and weld it open side up to the underside of the tongue; this would provide a crush proof runway for the copper tube.
Alternatively, two lengths of 3/4" x 1/4" welded on edge would also work, but would not be as strong.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-08-2010, 08:28 AM   #13
Keymar , Maryland
Bill
Remove the insulation and install cushioned Adel clamps. The insulation will increase corrosion since it traps water.
Michelle TAC MT-0
Sarah, Snowball
Old 03-08-2010, 08:53 AM   #14
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Black pipe is also code for propane
Kinked propane lines to stove imeynstein LP Gas, Piping, Tanks & Regulators 17 12-21-2008 06:50 PM
Propane tank, lines, regulator question Lothlorian LP Gas, Piping, Tanks & Regulators 16 02-27-2008 10:02 PM
Running propane lines Safari Tim LP Gas, Piping, Tanks & Regulators 7 07-01-2007 04:45 PM
propane lines airtim LP Gas, Piping, Tanks & Regulators 18 03-26-2005 08:38 AM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-02-2003 12:08 AM
