03-08-2010, 05:44 PM
#21
1993 34' Excella
Estancia
, New Mexico
Originally Posted by Birdwell57
Wouldn't black pipe be to rigid, and tend to rust?
First, I have not done it, just guessing, but have used black pipe for propane in other outdoor applications.
Too rigid? I don't think so. Would solve the crush problem though. Rust? yes, but I never saw black pipe rust through. I don't think black pipe is more rigid or rusts any quicker than your frame and axles.
03-08-2010, 05:50 PM
#22
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Originally Posted by azflycaster
On my 75 TW the main line is 5/8" and the branches are 3/8". I do not have any protection on my lines and they have held up well for 35 years. I also do not travel as many forest roads as you do.
These is the same sizes that are on my 1975 and my 1980.
I am away from my manuals. I do recall that the LP lantern uses 1/4" and all the feed lines have shut off valves on the under side of the trailer.
Aaron
WBCCI #XXXX AIR #2495
03-08-2010, 06:10 PM
#23
Naysayer
1968 24' Tradewind
Russellville
, earth
I see there is type L and construction grade, coil and pipe. Is there an important difference in grade? Should I use pipe or coil for the main line, or does it matter?
03-08-2010, 06:37 PM
#24
1979 23' Safari
1954 29' Liner
Orange
Rodney,
There probably is a difference, I used Type L.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
03-08-2010, 06:42 PM
#25
Naysayer
1968 24' Tradewind
Russellville
, earth
Originally Posted by wkerfoot
Rodney,
Bill
Is it a camper goes boom difference? I'd sort of like to avoid that.
03-08-2010, 07:05 PM
#26
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Rodney,
Think construction grade is the thicker under floor tubers...L is real flexy.
03-30-2010, 10:19 AM
#27
1969 31' Sovereign
Mount Vernon
Black pipe will rust to a point... then the collected rust actually acts to seal the pipe. That's why you never see black pipe rust through. I'm glad I found this thread, as I was leaning toward replacing my main line with the black pipe. I've done a lot of gas/propane piping and used black pipe for the main delivery line - even in direct bury situations - then used copper with in-line shut-offs for each appliance.
If it can handle being buried in the ground, I suspect it will do nicely on the underside of an AS.
One more thing just occurred to me: I had a 1963 Ideal travel trailer and its gas was hard piped right up to the appliances... just as if it were in a stick-built house. Short run... furnace, stove and refer only and all forward of the axles. I don't know if it was original or re-done... but that's how it was when I bought her.
03-31-2010, 02:27 PM
#28
1977 27' Overlander
1963 19' Globetrotter
Naples
Originally Posted by ROBERT CROSS
Rodney,
What are you calling construction grade ? L copper is is the industry standard,unless it is a Government job and a crazy architect designates K copper,both can be bought as hard 20' lengths,or soft 60' lengths,but you can only flare soft copper. Dave
03-31-2010, 02:32 PM
#29
1977 27' Overlander
Naples
Don`t know what code is used in Wa,I have been a plumber in several different states,only way I`ve ever been able to bury black pipe was to tape with asphalt tape
then paint with asphalt,another way was plastic coated pipe,then tape and paint the joints. Dave
04-04-2010, 09:30 AM
#30
1970 31' Sovereign
danville
you can flare hard copper you just have to aneal it first to make it soft.
04-04-2010, 10:29 AM
#31
1967 22' Safari
1960 Caravel
Edmonds
I had to look this up. Good info though. Thanks!
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
04-22-2010, 05:51 PM
#32
1956 16' Bubble
Dallas
, Oregon
what about copper tibing sizes? I'm rebuilding a bubble and have the same copper tubing size question. is there a flow problem if 3/8" is used from the dual regulater and branched off for 3 things. i will be hooking up a princess stove, norcold fridge, and a catalytic heater all of which have 3/8" fittings. do i need to use 1/2" for more flow under the trailer untill i get it through the trailer and reduce it down for the fittings? regards--ted
04-23-2010, 12:06 AM
#33
Maniacal Engineer
Lopez Island
Here's a chart that explains it.
Add up the BTU/hr ratings for your three appliances and see. Looks like you'll be fine, off the top of my head, but do the math.
- Bart
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Kinked propane lines to stove
imeynstein |
LP Gas, Piping, Tanks & Regulators |
17 |
12-21-2008 05:50 PM |
Propane tank, lines, regulator question
Lothlorian |
16 |
02-27-2008 09:02 PM |
Running propane lines
Safari Tim |
7 |
07-01-2007 03:45 PM |
propane lines
airtim |
18 |
03-26-2005 07:38 AM |
Bleed lines after propane refill!!!
Astrodokk |
On The Road... |
4 |
12-01-2003 11:08 PM |
