Old 03-08-2010, 08:08 AM   #15
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
Wouldn't black pipe be to rigid, and tend to rust?
Birdwell57 is offline   Reply With Quote
Old 03-08-2010, 08:34 AM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Another option...
THIS might be a viable option for those who require a more robust LPG line.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-08-2010, 08:53 AM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My '74 Argosy has copper gas lines. The main line is crushed near the hitch as well. I plan to replace that portion of the line to the first joint with copper, just rerouting it some to prevent damage from a jack or equalizer hitch. While some of the clamps holding the line to the bottom of the trailer have come lose, the line itself is still intact. It looks to me that when AS installed the line, they just riveted the clamps kind of willy nilly to the belly pan. There will be a lot better support when I get under there, the clamps will be attached to the frame members. No protective cover though, I want to be able to check for damage simply by looking under the trailer.
There are different kinds of copper tubing, make sure you read the application info on the box or package. Some are not rated for gas.
My '69 Shasta has 1/2" black iron. 41 years and there is no significant signs of rust.
Old 03-08-2010, 09:31 AM   #18
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
You know, Rodney, the old copper pipe on ours is pretty similar, including a compressed spot. Everything still works, sooo ....
I turned on the gas, made sure that there was gas in the line, and then slowly crawled along the length of the whole thing, sniffing every inch of the line, especially at joints. No leaks.
We decided to leave well enough alone.
Lynn
WBCCI 21043
Old 03-08-2010, 09:45 AM   #19
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If you are going to replace, use air conditioner copper,it is cleaned and capped,also no cover on the pipe,it can hold the salt water,which will make short work of the copper.Also don`t forget about electralous[miss sp],copper should not touch iron,not sure about aluminum,but I think not.Use the clamps with the rubber insulation. Dave
easyride is offline   Reply With Quote
Old 03-08-2010, 11:27 AM   #20
2007 25' Safari FB SE
Eureka Springs , Arkansas
We had propane lines installed Saturday (by a RV mechanic). He used 1/2" and 3/8" soft copper. He also said black pipe would work. Black pipe is cheaper, but with labor cost, I thought the copper would be quicker to install.
No wrapping, but used rubber hose for protection where line goes thru brackets.
triplenet is offline   Reply With Quote
Old 03-08-2010, 05:44 PM   #21
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
First, I have not done it, just guessing, but have used black pipe for propane in other outdoor applications.
Too rigid? I don't think so. Would solve the crush problem though. Rust? yes, but I never saw black pipe rust through. I don't think black pipe is more rigid or rusts any quicker than your frame and axles.
Old 03-08-2010, 05:50 PM   #22
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by azflycaster View Post
On my 75 TW the main line is 5/8" and the branches are 3/8". I do not have any protection on my lines and they have held up well for 35 years. I also do not travel as many forest roads as you do.
These is the same sizes that are on my 1975 and my 1980.
I am away from my manuals. I do recall that the LP lantern uses 1/4" and all the feed lines have shut off valves on the under side of the trailer.
Aaron
WBCCI #XXXX AIR #2495
Old 03-08-2010, 06:10 PM   #23
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I see there is type L and construction grade, coil and pipe. Is there an important difference in grade? Should I use pipe or coil for the main line, or does it matter?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-08-2010, 06:37 PM   #24
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Rodney,
There probably is a difference, I used Type L.
Bill
Just my personal opinion
Old 03-08-2010, 06:42 PM   #25
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Originally Posted by wkerfoot View Post
Rodney,
Bill
Is it a camper goes boom difference? I'd sort of like to avoid that.
Rodney
and the
My Blog
Old 03-08-2010, 07:05 PM   #26
Thumbs up
Rodney,
Think construction grade is the thicker under floor tubers...L is real flexy.
PFC
"Tahawus"
RLC
John Prine
Old 03-30-2010, 10:19 AM   #27
1969 31' Sovereign
Mount Vernon , Washington
Black pipe will rust to a point... then the collected rust actually acts to seal the pipe. That's why you never see black pipe rust through. I'm glad I found this thread, as I was leaning toward replacing my main line with the black pipe. I've done a lot of gas/propane piping and used black pipe for the main delivery line - even in direct bury situations - then used copper with in-line shut-offs for each appliance.
If it can handle being buried in the ground, I suspect it will do nicely on the underside of an AS.
One more thing just occurred to me: I had a 1963 Ideal travel trailer and its gas was hard piped right up to the appliances... just as if it were in a stick-built house. Short run... furnace, stove and refer only and all forward of the axles. I don't know if it was original or re-done... but that's how it was when I bought her.
Ellie & Carl is offline   Reply With Quote
Old 03-31-2010, 02:27 PM   #28
easyride's Avatar
1977 27' Overlander
Naples , Florida
Originally Posted by ROBERT CROSS View Post
Rodney,
What are you calling construction grade ? L copper is is the industry standard,unless it is a Government job and a crazy architect designates K copper,both can be bought as hard 20' lengths,or soft 60' lengths,but you can only flare soft copper. Dave
Kinked propane lines to stove imeynstein LP Gas, Piping, Tanks & Regulators 17 12-21-2008 05:50 PM
Propane tank, lines, regulator question Lothlorian LP Gas, Piping, Tanks & Regulators 16 02-27-2008 09:02 PM
Running propane lines Safari Tim LP Gas, Piping, Tanks & Regulators 7 07-01-2007 03:45 PM
propane lines airtim LP Gas, Piping, Tanks & Regulators 18 03-26-2005 07:38 AM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-01-2003 11:08 PM
