Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 08-17-2018, 08:09 AM   #1
Joannadannna's Avatar
2018 23' Flying Cloud
Dungville next to Donkeytown , Alabama
Ugh Ready to go and propane issues need guidance ASAP.
Packed and almost ready to head out today and went to turn on fridge and nothin’ ... clickity freakin !%#<!! click. So I thought I’d purge the lines by way of the stove - same noise with a tiny bit of propane smell. Still wouldn’t ignite. Unhooked each propane line to the tanks and reconnected and slooowly turned the valve to open position. And YES I have two full tanks of gas and my gut hurts! Batteries at 12.4 too.
I honestly don’t know what else to do here. Can anyone help me out trouble shooting this?
Thanks in advance.
~Joanna
You had me down as a damsel?
Darling, I'm the wolf.
Joannadannna is offline   Reply With Quote
Old 08-17-2018, 08:23 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Did you open the valve on the propane tank?
Do you have propane?
How long has it been since using the coach?
It may take several attempts.
Old 08-17-2018, 08:29 AM   #3
Yes
Yes
About 4 months
Got one burner started but it was making a lot of weird noises. Still better than nothing. I will note I’m on a slight decline in drive way now. Maybe that’s got something to do with fridge - but stove??
~Joanna
Old 08-17-2018, 08:35 AM   #4
Now not even one burner will come on. But I may have fridge running. Still something is out of wack— besides my temper this morning.
~Joanna
Old 08-17-2018, 08:51 AM   #5
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Thanks in advance.
Hi Joannadannna,
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 08-17-2018, 09:12 AM   #6
Originally Posted by AirstreamInc View Post
Hi Joannadannna,
Thank you.
Sent
~Joanna
Old 08-17-2018, 09:21 AM   #7
2000 30' Excella
Sarasota , Florida
Replace the LP regulator
I installed a new one in Dec, it failed in June. Now I carry a spare
GatorDave is offline   Reply With Quote
Old 08-17-2018, 09:22 AM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Thanks in advance.
My bet is on the regulator. Maybe Airstream can authorize a replacement at a local RV dealer, if you have one.
Al
Old 08-17-2018, 10:00 AM   #9
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I am clearly no expert however have you been able to use the refrigerator on electric? I ask only in trying to isolate the problem. Also can you get the hot water heater to work on propane? If so then you know the propane line is not blocked at least to the hot water heater. Also have you tried to light the stove burners with a match which is always a fall back option. Again if the burnt lights then you know you have propane tot he stove.
As to an incline that IMO should not affect the propane flow.
Anyway please let me know how you make out.
urnmor is offline   Reply With Quote
Old 08-17-2018, 10:05 AM   #10
2017 25' Flying Cloud
Cape Coral , Florida
Propane Blues
I've had difficulty getting the fridge to ignite on propane after a long dry spell. I suspect it may be nothing more than the propane in the lines has escaped. Be patient and keep trying the stove first of it is close to the propane tanks. Once you get that (or the water heater if you have water in it) lit on propane then move to try the fridge. It will still need several attempts in my experience. Possibly you have had bugs crawl into the line which is restricting the propane flow, that would be my other thought before something like a regulator.
Coach B is offline   Reply With Quote
Old 08-17-2018, 10:09 AM   #11
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Yes
Yes
About 4 months
You have air in the propane lines, you can get a lot of it out by burning the stove burners until they burn clean, it might be a challenge to get the air out of the fridge line without cracking a fitting open near the unit to bleed the line.
Old 08-17-2018, 11:01 AM   #12
Hey thanks all. I was supposed to have left and be one with the road by now, but instead I’m laying across my sofa like a sweaty sow off the pit! It’s humid, hot and miserable in the south and my mood ain’t no better. But I do appreciate the help. So the problem appeared to be 2 fold. First I had to purge a lot longer and disconnect tanks and do a reset with a slow release of pressure. Typically I don’t even start the fridge and bleed the lines on the stove and move onto fridge. However this time my stove wouldn’t ignite and when I finally got it working it was bitching up a hissy-fit making all sorts of odd noises. After all that chatter - I moved onto igniting fridge, which it did after a time. But then the darn stove wouldn’t light. Turns out my starter switch burned out or something because a couple of the lines connectors were fried. Pffft - brand new AS and albeit small problem, has boiled my beans. Will need to get that looked at. But for now I’m clear to go.... after a little snooze. You guys are terrific !
~Joanna
Old 08-17-2018, 11:30 AM   #13
Pittsburgh , Pennsylvania
Glad you got the frig to work and hope stove is working too. Hope rest your trip goes well. We just got back from week trip and our frig would not work on propane till we turned on stove first.
Alces2 is offline   Reply With Quote
Old 08-17-2018, 01:29 PM   #14
zapper's Avatar
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland , California
Sorry for the frustration. But after my rig is in storage for months and I am getting ready to leave like you I start the stove burners, then additionally the hot water heater and after a few minutes then I start the fridge. If this doesn't work, then look to the gas regulator. Or if you can still buy a pressure gauge that measures in inches of water column and if my memory serves me correctly the fridge needs 10" of water column pressure to work properly. Good luck.
zapper is offline   Reply With Quote
Old 08-17-2018, 01:57 PM   #15
Box Elder (formerly Long Island, NY) , South Dakota
There is a SAFETY feature that shuts off the propane IF the valve is opened TOO QUICKLY (the system thinks there's a propane leak). Try closing the propane valve, wait a few minutes (so the safety system can reset), and then slowly open the valve. Once fully opened, check at the stove again and see if you now have propane. If you do, then start the fridge and or other gas appliances. Good luck!
NY24 is offline   Reply With Quote
Old 08-17-2018, 02:29 PM   #16
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Every time I bring ours out of storage I turn on the propane and open all the stovetop burners and keep rotating the igniter until all burners light (takes at least 30-45 secs and the rear left is always last to light) then I turn the furnace on. I let the burners and the furnace run at least one minute and then turn the fridge and water heater on. Works every time. If you do this and you still have problems then as people have said it’s probably a regulator or blocked line issue.
SuperTrouper is offline   Reply With Quote
Old 08-17-2018, 02:44 PM   #17
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Thanks in advance.
Hope you got er going, did anyone mention trying the other tank? assuming the new trailers still have a manual tank selector.
Anyway real reason for being here was to say to turn on your refer at least the day before you plan to leave, gives it the needed time to get down to temp. and if you have a glitch you at least have another day to sort out.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Need guidance on rivet kit and supplies nhdalton Ribs, Skins & Rivets 7 04-28-2015 08:12 AM
asap-Newbie-100lb propane old valve 2 new adapter (ODP) BrianD. Full-Timing, Winter Living & Workamping 1 06-20-2010 10:30 PM
need asap 1975 argosy door lock and handle etc Gosman Doors & Locks 3 06-14-2010 06:00 PM
UGH...previous owners and a locked door! aircooled4 Doors & Locks 5 02-01-2009 06:51 PM
