Old 09-16-2015, 05:23 PM   #1
Arlington , Virginia
Turning Propane Off?
State laws seem to vary. Is there a need to shut off the propane supply anytime when driving or only through tunnels? Does it conserve propane to shut off the supply when you are not using it for a few days? How about re-lighting pilot lights ... any guidance for that in an AI Grand Tour or is it just unnecessary to shut off the gas in the first place?
xCliff is offline   Reply With Quote
Old 09-16-2015, 05:30 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I do not turn my gas off when on the road.
MICHAEL
Old 09-16-2015, 07:03 PM   #3
1974 Argosy 20
Kooskia , Idaho
With electronic ignition on refrigerators, water heaters and furnaces, virtually nothing has pilot lights anymore on newer rigs. Propane does not leak out of pipes and fittings when not being used, it would be very dangerous if it did. So there is no savings in turning it off when not being used.
Old 09-16-2015, 07:18 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I always turn mine off when not in use in case there is a leak. The trailer sits outside and always had a window open, so I am not worried about danger. I do it to keep the tanks from emptying in case of a leak.
CRH is offline   Reply With Quote
Old 09-16-2015, 07:25 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the only time that my propane tanks are turned off is when my trailer is not being used. [parked/in storage]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Battery disconnect not turning off Hammertime Sprinter and B-van Forum 10 08-26-2017 05:47 PM
Atwood gas hot water heater not turning off murphy Water Heaters, Filters & Pumps 2 06-27-2014 02:04 PM
Turning off refrigerator before fueling TV kswelsh Refrigerators 29 11-14-2013 05:35 PM
Turning off Sureflow system when connected to city water bonginator Water Heaters, Filters & Pumps 18 05-06-2010 08:37 AM
