Old 03-29-2006, 09:09 PM   #1
bimi's Avatar
Tote Tank Woes now Fixed!
Hi everyone. I don't know if any of you have had this problem, but last year I was camping at Isle du Bois campground in Pilot Point, Texas, when I unfortunately had to pull my tote tank about 1 mile to the dump. I creeped along as slowly as my truck would let me, but by the time I got to the dump, my plastic tote tank wheels had literally melted under the weight. Well, I have been looking for quite some time and finally found these replacement wheels. They are a little wide, but the offset worked well. I found them at the 2nd Tractor Supply store I went to. By the way, I ordered some that were the right size from them, but both sets that they ordered came in with a 1/2" bore rather than a 5/8" bore. I am attaching a picture for you all to see.
By the way, just in case anyone needs the measurements, here they are.
Wheel 9 1/2" to 10" diameter
1 3/4" tread width
5/8" shaft or bore
2" max hub length
Now, the tires I bought are pneumatic tires that are 10" in diameter, and the hub length is pretty much maxed out. But, they clear the tank and roll great since they have metal hubs and BEARINGS! Why Tote Tank put plastic wheels on these things is really beyond me.
Also, I was able to reuse the shaft end caps by hammering them back into shape.
I hope you never have my same problem, but if you do, this is a good solution. I don't have pictures of my melted wheels, but I will post them for you to see also.Click image for larger version
Name:	tote fixed.JPG
bimi is offline   Reply With Quote
Old 03-29-2006, 09:33 PM   #2
Images: 59
You need to think up a name for your Monster Blue tote on steroids.
Like "Blue Thunder", or "The Eliminator", or "Grave Digger", or "Super Dumper" or "Monster Stinky"
Old 03-29-2006, 09:35 PM   #3
bimi's Avatar
I definitely think that "Blue Thunder" would be the most appropriate! We could even have a theme song "The Thunder Rolls!"
Old 03-29-2006, 09:43 PM   #4
Images: 59
Everybody needs a theme song!
What about the yellow streak in the picture. Is that a camera problem?
Old 03-29-2006, 09:46 PM   #5
bimi's Avatar
That was funny! Actually, the carpet in the background is going in as soon as I get all of the tint removed from the windows. I am getting tired of the green shag. We bought a new dyson vacuum cleaner, and it is so much more powerful than our old vacuum that it sucked up large chunks of the old carpet. It was amazing!
Old 03-29-2006, 10:04 PM   #6
mandolindave's Avatar
Very cool..............
Thanks for sharing the great idea and passing along the specs.
But where are you going to mount the spare????
Just a heads up. My buddies say the wheels usually fall off.
The axle mounts may be the weak link for you now.
mandolindave is offline   Reply With Quote
Old 03-30-2006, 03:41 AM   #7
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Awesome!
BIMI,
Great! I'm glad you checked the Tractor Supply Store. What size tank is that? 16 gallon? Will those wheels work on a 10 gallon tote?
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 03-30-2006, 08:45 AM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
hmm...I think now you need to call Henry from Axis and see if he can make up a custom torsion axle for that bad-boy.
really...thats why they call them "tote" tanks. so you can just "tote it over there". not really meant for "over the road" excursions. I've run into that situation, too, with a far-off dump station. really a pain!
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 03-30-2006, 08:59 AM   #9
Images: 59
There has to be a way to add a motor and a steering axle. Maybe something from a large radio-control truck?
Old 03-30-2006, 10:10 AM   #10
Cracker's Avatar
Pittsfield , Maine
Tote
I think that it's time for a design contest to produce a new Tote! Just think, pneumatic tires, torsion axles, on-board loading/discharge pump, 30 mph top end, polished aluminum, and, of course, pinstriping! Ahhh - a thing of beauty!
Cracker
Cracker is offline   Reply With Quote
Old 03-30-2006, 10:25 AM   #11
bimi's Avatar
OK, now that I have the "blue thunder" tote tank with the custom "off-road" package, I have decided to insert a cool signature like so many of you have. Check it out below this message and let me know what you think.
2002 Dodge 1500 4x4 quad cab, 1971 Ambassador International, 1 Bad-Boy Tote Tank
Old 03-30-2006, 11:02 AM   #12
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I've already got a steering axle...and a built-in dump valve.
and I know what you're thinking. my tow vehicle is much too small to be hauling such a load. underpowered...short wheel-base... I should really have a 3/4 ton, and at the very least, a hensley. but what can I say? I'm a rebel....
Air:291
Wbcci: 3752
'73 Safari 23'
Old 03-30-2006, 11:29 AM   #13
basecamp's Avatar
1996 30' Excella
Bowmanville , Ontario
Would it be inappropriate to call it a turdmobile? If Chip Foose(Overhaulin)gets a whif of this idea he would probably design it with 22's no 10" wheels.
Hensley Hitch, Jordan controller
basecamp is offline   Reply With Quote
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 07:11 AM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 04:40 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 01:57 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 09:52 AM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 07:52 AM
