Old 07-20-2007, 08:25 AM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Thread compound?
I have purchased a new automatic switch over regulator for my rig. I noticed on the instructions if said to use pipe thread compound on the gas lines to ensure good seals at installation. I always thought pipe thread compound on gas lines was a no-no. What's the scoop here.
wacnstac is offline   Reply With Quote
Old 07-20-2007, 08:56 AM   #2
SaabLover's Avatar
Almost Always Sunny Sarasota , Florida
Images: 12
The use of any kind of sealant on flared fittings is most definitely a no no. But on pipe fittings it is ok. Here is something to check out if you are not sure. I alway check for leaks after I have it all hooked up with a soapy water solution. Use a small flux brush and with dish soap and water (10% soap and 90% water). If you see bubbles that is where the leaks are.
Installing a gas connector
SaabLover is offline   Reply With Quote
Old 07-20-2007, 09:04 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If you want to use compound, my suggestion would be the yellow teflon tape that is approved for gas line installations. I have a roll of it at home that I bought years ago at the hardware store. The older putty type stuff was really for use on threaded black pipe lines that were prevelant years ago in older homes.
Jack
Jack Canavera
STL Mo.
AIR #56
Reopen The Thread Camper! airstreamcaravel Our Community 8 12-04-2008 11:33 PM
