Old 07-19-2011, 11:42 AM   #1
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
Thoughts on condition of tank?
What are your thoughts on the condition of the tank in this picture? I bought this 76' MH and need to go pick it up. Should I replace anything, upgrade, etc. How should I address the rust? Should I replace all lines? I don't know much about LP systems yet.
thanks
Name:	More Argosy Pix 003.JPG
MrJ is offline   Reply With Quote
Old 07-19-2011, 12:00 PM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Go By and Let Hank Hill Check It! LOL!
Once you have the MH just drive it by the local LP dealer. They will check your LP systems for you and make any repair recommendations as to what they find. It will cost you nearly nothing compared to the piece of mind & the knowledge that it was all checked out by a pro! Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-19-2011, 12:03 PM   #3
Images: 59
Legally you don't need to replace the valves on older horizontal tanks, but they still need to be inspected and recertified by Hank Hill every 5 years.
Old 07-19-2011, 12:39 PM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Ugh. It's got rust, but how bad is the pitting from the rust. If it's fully superficial, then a good derusting and recoating would do. However, if it's pitted, well, think about it this way: Here in NM (and in many other states), it is the filler's option to reject filling a tank that is in poor shape, regardless of certification and valves.
Lynn
WBCCI 21043
Old 07-19-2011, 02:01 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I had the tanks for my trailer tested and re-certified. They found a bad valve. Total job was under $100.
Bill M. is online now   Reply With Quote
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
69 Overlander water tank swap colin57 Waste Systems, Tanks & Totes 2 04-24-2011 08:23 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
