Old 10-06-2011, 09:28 AM   #29
1981 31' Excella II
New Market , Alabama
There is nothing special about the line. Plain water grade pipe is fine. You can get yellow coated copper from Mcmaster.com. The yellow identifies it as a gas line and the coating also helps protect the pipe from corrsion and chaffing. You have to strip the yellow coating off before using a fitting. The copper lines are good for several hundred psi and you are using about 5psi. The same type of 37 degree flare fittings are used in aerospace applications all the time. You don't need tape or seals other than a good flare on your tubing. If the flare is split or damaged you need to cut it off and make a new one. Soapy water is great for checking leaks and you need to check all joints after making repairs. Copper and brass are not going to be harmed by the soap but you can wash it off if you like. If you need to use tapered pipe threads (NPT) on something use teflon of whatever color you like and use one layer. More layers and it will bunch up and not seal. Use only brass or stainless steel pipe fittings.
The main reason for the overkill on the lines is in case the regulator fails in which case you have about 100psi to deal with.
Perry
Old 10-06-2011, 10:55 AM   #30
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
I'm quite sure it is a flared fitting!!
If you are handy with a flaring tool .
I would consider making it a double flare.
Some times single flares have a tendency of cracking over time.
I used to do a lot of flaring of copper pipes on older buses .
We always double flared so lines wouldn't break!!!
william Haym is offline   Reply With Quote
Old 10-06-2011, 11:00 AM   #31
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
Copper pipes used for propane applications are thicker.
To reduce breakage. A lot more sturdy!!!
Old 10-06-2011, 11:24 AM   #32
1981 31' Excella II
Copper pipe has gotten cheaper and cheaper and thinner and thinner walled. The stuff in my house rotted in less than 20yrs but they used the cheap stuff. About half way down on this page you will see the yellow coated copper gas line.
http://www.motorcycleproducts.org/AS...opper-Pipe.pdf
Perry
Broken rivet-Is this normal? crios Ribs, Skins & Rivets 8 09-11-2011 08:18 AM
How much vibration is normal? jeffwink Wheels, Hubs & Bearings 8 06-28-2011 08:49 PM
Back skin normal? akacheryl Ribs, Skins & Rivets 8 06-08-2011 11:30 AM
Is sagging floor at wheel well...normal? MDSilverado Repairing/Replacing Floor &/or Frame 4 05-14-2011 08:01 AM
Carrier Normal Profile - Add Drain Line vhariable Furnaces, Heaters, Fireplaces & Air Conditioning 7 05-01-2011 01:51 PM
