Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 07-29-2009, 03:54 PM   #1
Profile:  1970 25' Tradewind
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
the rod that holds my tanks in place ....
seems to be screwed in place with maybe a bolt,or maybe a pin ...any idea as to whats really holding it in ,I need to replace the rod tomorrow,and am stumped,Thank You !
Rollerboy is offline   Reply With Quote
Old 07-29-2009, 04:04 PM   #2
memgrove2000's Avatar
Profile:  1972 31' Sovereign
Elkhart , Indiana
On Our 72 it is held to the trailer frame with a Cotter pin! A lot of people will replace the rod with a threaded rod and use two nuts to hold it in place ( one on top of the mount and one under) You may need to turn it with vise grips. Ours was a bit rusty.
Mike
Have a great day!
1972, 31 Foot Sov. Intl.
memgrove2000 is online now   Reply With Quote
Old 07-29-2009, 04:12 PM   #3
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
Ditto, I got rid of it too and replaced it with a length of all-thread of the same diameter and thread type, available from any hardware store or Home Depot. Then, since the upper handle was permanently welded/corroded to the old rod, I used a nylon lock nut, with big washer, up top to hold the old bottle clamp-thing securely down on the bottles. Works great, didn't cost much. As for getting the old one off, you'll see how once you really look at it. good luck! -tim
tphan is offline   Reply With Quote
Old 07-29-2009, 04:27 PM   #4
Gaylord , Michigan
no cotter pin here....I would have noticed that for sure,unless it broke off and that's what is holding it all in place
Old 07-29-2009, 04:34 PM   #5
Profile:  1977 31' Sovereign
McHenry , Illinois
Factory actually used a very small straight pin. It is so small it is hard to see. Rumors are that it also breaks after some time and corrosion. I like the threaded rod. I bought the galvanized type to help reduce the rust. When it rusts, it is time to replace it. Hot dip galvanize lasts a lot longer than the plated galvanize.
Old 07-29-2009, 06:01 PM   #6
mello mike's Avatar
Phoenix , Arizona
Images: 14
That's no rumor. It happened to me. Here's my report on what happened.
Read This... Disaster Averted
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 07-29-2009, 05:11 PM   #7
mello mike's Avatar
Phoenix , Arizona
Images: 14
Just curious, which tank are we talking about here?
Old 07-29-2009, 05:39 PM   #8
tphan's Avatar
the propane tanks.
Old 07-29-2009, 05:20 PM   #9
Profile:  1974 31' Sovereign
flint , Michigan
Mine has a roll pin.
flashbackk is offline   Reply With Quote
Old 07-29-2009, 06:08 PM   #10
Diesel1's Avatar
Profile:  1967 24' Tradewind
Kingman , Arizona
My 67 Tradewind has a small roll pin. On mine I removed the roll pin and lowered the rod to the next factory predrilled hole which allowed me to use the smaller propane tanks. Adios, John
Diesel1 is offline   Reply With Quote
Old 07-29-2009, 07:15 PM   #11
Elkhart , Indiana
Maybe the pin in ours was an "on the road" repair? I havent come acrost a page in the trailer journal about it. We have 20 lb. tanks and there is a short section of the rod hanging lower than the frame.
You may find that wire brushing the area will help find the pin.
Mike
Have a great day!
Old 07-29-2009, 07:42 PM   #12
Gaylord , Michigan
my roll pin seems to be shorter ,and sunk beneath the surface, I may have to drill out the old and insert the new,Thank You
Old 07-29-2009, 08:08 PM   #13
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
From the 72 manual.
Using a 3/16 drift punch, drive pin rearwards to allow rod to be removed. A heavy bar or hammer held against the ring above pin on the rear will lessen amount of drive force needed.
Replace by reversing above procedure.
Clear as mud.... have fun....
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 07-29-2009, 08:22 PM   #14
Elkhart , Indiana
I love to read from the service manual too. "clear as mud" is right!! It is at least good for the pictures!
Mike
Have a great day!
HHOT ROD / Lightning Rod ROBERTSUNRUS Water Heaters, Filters & Pumps 4 07-11-2009 06:03 PM
What holds up the bed?? frank n'shar Cabinets, Counter Tops & Furnishings 9 10-04-2007 09:10 PM
What holds up you patio lights? Cedars Community Polls 16 05-15-2005 04:47 PM
what holds black water tank in place tw64 1959-69 Tradewind 3 06-17-2004 12:05 AM
Hott Rod & Lightnin' Rod femuse Water Heaters, Filters & Pumps 6 09-22-2003 12:46 PM
