Join Airstream Forums Today
Old 05-04-2006, 06:15 PM   #1
azflycaster's Avatar
1975 25' Tradewind
Phoenix , Arizona
Images: 67
Thank you Santa!
Well, I just arrived home and guess who must have stopped by? My neighbor said he tossed the red outfit and sled and now drives and dresses "Brown". See if you can find what Santa brought in the picture.
Hint = I got 2...
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 05-04-2006, 06:18 PM   #2
Well Preserved
overlander63's Avatar
Colfax , North Carolina
Aww, gee, he left you a couple of frog ornaments to decorate your pool. How nice!!!
But why do you have your new Worthington LP tanks at the pool?
Some days, it's just not worth chewing through the restraints.
Old 05-04-2006, 09:08 PM   #3
1975 25' Tradewind
Phoenix , Arizona
Images: 67
Gracie thought they were her scuba tanks! Now that I have the new tanks, how about suggestions on how to shine them up? They have a few rough spots towards the bottom. Would you start with a wet sand job to smooth them out and then start the polish routine?
Richard
Old 05-04-2006, 09:22 PM   #4
New York , New York
Images: 27
It took me just two hours each. Finishing sander, sweatshirt material, Mother's mag wheel polish. No pre-sanding, nothing. Straight into the polish. There may have been an easier way, but I'm not aware of it. I wonder if either a 3m 0000 abrasive pad or a Mr. Clean Magic sponge would have sped it up a little?
__
65GT is offline   Reply With Quote
Old 05-07-2006, 07:23 PM   #5
1975 25' Tradewind
Phoenix , Arizona
Images: 67
built a stand today out of some scrap wood in the shop. Then spent 20 minutes with wet and dry (wet) 220 grit sandpaper. I just did the bottom of one tank to knok off the splatter from the welding. It is starting to look good.
Richard
Old 05-13-2006, 04:14 PM   #6
1975 25' Tradewind
Phoenix , Arizona
Images: 67
Getting the tanks done a little at a time. I do have some great excuses why it's not done yet. Here is where I am at now
Richard
Old 05-13-2006, 07:27 PM   #7
Well Preserved
Yes, someone is reading your posts--
The polish job looks great. Now, if I only had time to polish mine that well.
Old 08-30-2008, 09:56 PM   #8
bredlo's Avatar
1954 22' Safari
Evanston , Illinois
Send a message via AIM to bredlo
I realize this is 2 years later, but in case others find this post while searching for advice on polishing Worthingtons - thanks for a great idea here, Richard.
You inspired me to build my own cradle out of 2x4 scraps in my garage as well. Here are the results - minus the beach towels I used as pads on each end. I built it from about 6 feet of 2x4's, 16 drywall screws and a miter saw to get good angle cuts for the top pieces. Took all of 15 minutes from beginning to end.
I found hand sanding to be a major pain, and after many hours got only mediocre results at best. That was 220, then 300, 400 and 600, and finally Nevr-Dull wadding polish.
Next I fired up the Cyclo and dabbed a few fingerprints of F7 Nuvite on the tank. I ended up with the results below in about an hour. I can't be sure the sandpaper didn't help prep the surface, but I'll figure that out tomorrow when I try to do the other tank using only the Cyclo/Nuvite.
Name:	tank cradle.jpg
ID:	66594   Click image for larger version
bredlo is offline   Reply With Quote
Old 09-17-2008, 01:57 PM   #9
reggiemon's Avatar
1959 18' "Footer"
Corpus Christi , Texas
Interesting, Brad. What was the outcome on the 2nd tank?
Tanks.:>)
reggiemon is offline   Reply With Quote
Old 09-17-2008, 02:25 PM   #10
Yes, yes Terry... I, too, wish that you had found some time to polish yours up to a mirror shine...
And I am also interested to see how Brad's polishing went on the second one without the sanding prep?
Old 09-17-2008, 03:05 PM   #11
bredlo's Avatar
1954 22' Safari
Evanston , Illinois
Tanks.:>)
Well, for better or worse - all that hand sanding did make things look really easy for the Cyclo, when it fact the Cyclo was just finishing up the job. The second tank came out just as good, but required a lot more time with the Cyclo.
Overall, I'd skip the hand sanding and go for the Cyclo, except in the places where it can't reach. For that, I used 400, 600 and 800 sandpaper by hand, followed up by Nevr-Dull wadding polish. Worked very well.
Old 09-17-2008, 04:10 PM   #12
64airstream's Avatar
1964 22' Safari
Beaver County , Pennsylvania
Brad,
Two thoughts:
1. I think a final photo is in order.
2. If you put a little poly on your tank stand and put it in a box with a couple pieces of sand paper, I'll bet you could sell it on e-Bay as an Airstream Tank Polishing Kit.
Great job, and one of these days, maybe the day after this Christmas, I can put your experience to good use.
Thanks for sharing,
Roy
64airstream is offline   Reply With Quote
Old 09-17-2008, 04:12 PM   #13
1964 22' Safari
OOPS - I guess that should have gone out to AZ as well.
Old 09-18-2008, 01:16 PM   #14
bredlo's Avatar
1954 22' Safari
Evanston , Illinois
Originally Posted by 64airstream View Post
Brad,
Two thoughts:
Thanks for sharing,
Roy
Fair enough!
I still need to finish up the handle on the second tank, and lots more polishing to do in general... but here's proof I did tackle the second one.
And great idea on selling my pile of 2x4's, er, tank cradle. "Tank Polishing Kit" does have a nice ring to it!
santa clara ca unit rally/event wunderful62 WBCCI Rallies & Events 1 06-22-2003 10:11 PM
Santa Maria Show Excella3287 Our Community 1 12-26-2002 05:03 PM
Dear Santa...I can explain! KY Girl Off Topic Forum 6 12-22-2002 10:32 PM
WBCCI VAC Santa Maria rally 1958 Flying Cloud WBCCI Rallies & Events 11 12-04-2002 10:01 AM
Christmas in an Airstream.... Silver Bullet On The Road... 8 12-02-2002 09:20 PM
