Old 08-01-2004, 12:16 AM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Testing regulator auto switch over
Is there a simple way to test the red flag indicator on the gas regulator?
I thought I could just light a burner and turn the service tank off thinking it would set the indicator and pull from the second tank. But it did not work that way. The burner kept working but no indicator.
I had my regulator inspected by a gas service company and it was ok then. It's the original.
-Tim
theVAP - Airstream Podcast
Old 08-01-2004, 09:06 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Tim,
The way you did it is the way to test it, but the question is: how long did you wait? The cook top is not a high demand appliance. The regulator steps the propane pressure down from high pressure to approx 3 PSI if you have the water heater lit and do the test you should see action in less than 5 Min.
Be sure to have the arrow pointing toward the tank you are about to turn off.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-01-2004, 11:39 PM   #3
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Ah, Thanks for the info Brett. I'll retest it!
-Tim
3 way switch Ultradog Electrical - Systems, Generators, Batteries & Solar 3 07-04-2004 01:13 PM
Testing breakaway switch Sneakinup Brakes & Brake Controllers 6 03-20-2004 10:45 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
Break Away Brake Switch davespann Brakes & Brake Controllers 1 07-30-2003 08:22 PM
Light Switch JOECAR 1975-1976 Excella 500 1 03-16-2003 08:30 PM
