Old 08-12-2005, 04:14 PM   #1
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Tapping propane
I posed this question on another board earlier today. It was probably the wrong place. Forgive me, I'm relatively new at this and I'm still euphoric at earning my second rivit.
Anyway, would anyone have any suggestions of what would be the best way of tapping off of the propane tanks on my Bambi to run an outside barbecue, lights, etc., so i wouldn't have to carry an extra cylinder? Is there a way, or a device, to do it without splicing into the copper line?
Thanks.
SilverRanger is offline   Reply With Quote
Old 08-12-2005, 04:24 PM   #2
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
On The Road , U.S.A.
Here ya go ... http://www.marshallbrass.com/rv.htm
Porky
TrailerGypsies.com
WBCCI #3405 Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 08-13-2005, 06:15 AM   #3
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Thanks, Porky. The Extend-a-Flow Plus should work out just fine.
Old 08-13-2005, 11:03 AM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
That looks cool. How does it work? I'm still considering one of those propane campfires, and it would be great to tap off the trailer's tanks to run it.
Stephanie
Old 08-13-2005, 11:07 AM   #5
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
The Firedancer campfire is neat but... the attached propane hose is about 8 feet long. SO.... your fire would have to be pretty close to your trailer. It might be simpler just to get a smaller dedicated bottle for the fire or.... take a tank off your trailer to run the fire.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 08-13-2005, 11:51 AM   #6
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Can't you add a longer hose to the firedancer, or replace the hose that's on it? Dragging a tank around would be..well, a drag
Stephanie
Old 08-13-2005, 11:55 AM   #7
Janet H's Avatar
1964 26' Overlander
Images: 90
I'm sure you could extend the hose - but replacing might be dicey... I think the simplest thing is to take a bottle off your trailer..... If you start with full tanks - you can have a lot of fires before you are propane-less.
Old 08-14-2005, 11:05 AM   #8
markjoandall's Avatar
2001 30' Excella
Bedford , New Hampshire
extend a flow
FWIW, I purchased the extend a flow and have found that it reduces the pressure of the gas and the refrigerator refuses to work on gas. This is only true when the regulator is turned to the bottle with the extend a flow installed.
Talk about frustrating and difficult to find. We had a regulator (original with trailer) that delivered about 9 inches of pressure and nothing worked then when we replaced the regulator with one that delivered the 11 inches required the refrigerator worked fine. The extend a flow must just reduce the pressur only that little amount for the fridge not to work.
This was our experience.
Mark
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Old 08-27-2005, 02:37 PM   #9
1977 28' argosy moho
scarborough , ontario
Congrats on your second rivit! I took a line off my propane tank on my motorhome for a BBQ and it works great. None of my outdoor storage cupboards were anywhere near big enough for a 20 pounder so I had no other choice. My fridge, furnace, hot water and stove all work the same. Being careful, taking your time and using the proper hardware are important components when working with propane. Good luck!
Warbs is offline   Reply With Quote
Old 08-27-2005, 06:58 PM   #10
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
If one had two propane tanks, as do most, if not all Airstreams, simply disconnect the inactive tank and hook up your appliance. The regulator will draw from the only tank hooked to it. You just won't have a backup if you run out on the active tank, as you would with both tanks connected. If you have the older brass connections they do make a female brass "plug" to keep dirt and debris out of the disconnected line.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane valve leak Dbraw LP Gas, Piping, Tanks & Regulators 3 06-14-2002 06:12 PM
