Old 07-12-2007, 02:04 PM   #29
Devils Lake , North Dakota
Originally Posted by Sundance
What in the world makes aluminum tanks worth more than 5 times the steel ones? Is it just for looks?? Weights a non issue as it re-cert requirements so it has to be a vanity thing.
Well where is the crow???? The "steel" tanks that I thought were excellent with zero rust turned out to be.................. You guessed it. Aluminum!!
Yee Haa
Now I have changed my opinion and aluminum is well worth 5 times the cost of steel.
Sundance is offline   Reply With Quote
Old 07-12-2007, 02:27 PM   #30
1976 25' Caravanner
Campton , New Hampshire
Yee Haa
Two lbs. of fresh crow will arrive Saturday via UPS.
Now you're one of the RICH guys
ticki2 is offline   Reply With Quote
Old 07-13-2007, 08:29 AM   #31
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I have a pair of 30# tanks for sale. Located in eastern Oregon. I upgraded to 40#s.
Michelle TAC MT-0
Sarah, Snowball
Old 08-09-2007, 08:02 AM   #32
tinsltootsie's Avatar
On the tank issue....what is the cost to have new valves put on aluminum?? We replaced ours with steel when our local guys wouldn't refill them. I think they're 30 lbs, at least whatever would normally be on a 27 ft overlander... they're bigger than a grill tank and in good shape. Just wondered on the cost of the new valves. We haven't decided what to do with them yet, but we still have them.
It's the rivets!!!!!
tinsltootsie is offline   Reply With Quote
Old 08-09-2007, 08:22 AM   #33
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
It's about, as already said, and from my recent experience, 45$us (60$can).
Mine were done the same day. Brought them in in the morning got them back before 4 PM.
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 08-09-2007, 08:40 AM   #34
1976 25' Caravanner
I paid $40 for the 2 valves and another $50 to install , re-certify , and fill both tanks . This was done at a local gas supplier who also sells appliances .
Old 08-09-2007, 10:36 AM   #35
I got my OPD valves off ebay for $29 for the pair. Solid brass and nice valves.
I installed them myself (easy) and the local propane dealer recertified them for free when I filled them. The valves I got already had the blue tread seal on them and were ready to go.
I decided to just paint them white again. Less possibility of theft now that I know they are spendy rascals.
Old 08-09-2007, 10:38 AM   #36
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Sundance,
Aluminum tanks take a different valve than steel tanks because the profile of the tank is different. I hope you purchased the valves for aluminum and not steel tanks.
Bill
Just my personal opinion
Old 08-09-2007, 07:47 PM   #37
hmmm. Not too pricey. I bet my husband paid more for new steel ones! (then we painted them silver!)
Old 08-16-2007, 06:02 AM   #38
Bill,
I had no idea there were different valves for aluminium. The supplier did not indicate this. After looking up some info I see the only difference is the dip tube length. Steel is 4.8" and aluminium is 6".
I can't think of any real safety issue. Having never had a problem with Non-OPD valves this has to be at least safer than the old valves???
All the suppliers I know of and have used fill by weight..... so the OPD valve is overkill for me.
It works..... That said. Thanks for the info. Had I to do it over again I would get the "correct" valve.
Old 08-16-2007, 10:54 AM   #39
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Bill,
Sundance,
The difference is the length of the dip tube, this is because the aluminum tanks have a different profile than the steel tanks. If you always fill by weight, do you start with a completely empty tank or do you know the gross weight of a full aluminum tank, which will be less than a full tank?
Since the length of the steel valve is less than for an aluminum tank, if the filler uses the OPD valve as a shut off, your aluminum tank will be overfilled.
Bill
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
