Old 10-13-2006, 07:58 PM   #15
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
We have original Worthington tanks - made here in Columbus Ohio. Our 71 was purchased in July - one tank had been recertified in 06/04 with new OPD - the other original. Bought a new OPD for the other and tried to replace myself - didn't have the right tool to tighten it enough.
Took both to a SOB RV dealer for refill - they tightened the the new valve for free and filled both tanks. Advised us to take the recertification number engraved on the first tank and engrave it with a Dremmel in the second and "you'll be good for another 10 years". "Certification is required every 12 years". "These are Worthington aluminum tanks - you'll not have any problems with them" was the advise.
Took the tanks back to the campground where we have her parked for now. Neighbor stopped by and said those are odd tanks - look like aluminum. I had one of those but it cost so much to change the valve we just switched to a new steel tank. Smiled and went back to work.......
Old 10-28-2006, 06:39 AM   #16
1987 32' Excella
Flanders , New Jersey
I receintly got my 87 32' excella, the propane tanks were updated, would any know where I can get the outside sensors to monitor the LP gas level in the tanks from the control panel??
Squishey is offline   Reply With Quote
Old 10-28-2006, 06:40 AM   #17
1987 32' Excella
And would that same sensor run the outside temperature gauge also on the control panel??
Old 10-28-2006, 07:45 PM   #18
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Squishey,
Last year the A/S dealer near Grand Rapids MI parts guy told me that I could order the tanks and probes from Airstream that would work with the panel on my '79 -- for five hundred dollars each.
I said, "Thank you."
Lamar
On edit, that's "Grand Rapids," not "Grand Rabids."
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 03-24-2007, 06:14 AM   #19
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Originally Posted by Chopper
Hi all,
The picture is of my newly acquired old '74Argy26 undergoing a renewal. Are the propane tanks original and therefore in need of replacement?
Thanks!
Oh yea! Aluminum all the way. My two new 30# came the other day. Paid big buck for the Worthingtons but worth every penny. Once you polish them up don't forget to lock them up. Changing the valves is really worth it.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 04-11-2007, 06:41 PM   #20
1995 34' Limited
Livingston , Texas
So far I have been told in Texas and New Mexico at various propane dealers that there isn't a new OPD valve that will fit the horizontal aluminum tanks. They just want to slap a sticker on it saying it is safe, but my valve threads are wearing down anyway and I need to replace them. Right now I am at American RV part located at Anthony, Texas. Does anybody know of a propane dealer in West Texas or Southern New Mexico that could replace them for me? I am getting tired of the run around. Thanks,
Stephen
steptex is offline   Reply With Quote
Old 04-11-2007, 06:55 PM   #21
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Nope two totally different sensors.
Aaron
WBCCI #XXXX AIR #2495
Old 07-10-2007, 05:02 PM   #22
Devils Lake , North Dakota
What in the world makes aluminum tanks worth more than 5 times the steel ones? Is it just for looks?? Weights a non issue as it re-cert requirements so it has to be a vanity thing.
Sundance is offline   Reply With Quote
Old 07-10-2007, 05:16 PM   #23
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Sundance,
Weight is an issue, the aluminum tanks weigh less than a steel tank. Aluminum tanks don't rust and our trailers last much longer than SOBs. My newest Airstream is 28 years old with the original aluminum tanks, I am not sure that if the tanks were steel that they would still be safe. FYI, new Airstreams come with steel tanks.
Bill
Just my personal opinion
Old 07-10-2007, 05:20 PM   #24
hey Bill..........
My 73' Argosy still have the stock original steel tanks and they look great.
I'm going ahead and installing OPD's and re-cert if I can't sneak them by the refill :-)
Old 07-10-2007, 06:18 PM   #25
1976 25' Caravanner
Campton , New Hampshire
hey Bill..........
Steel tanks rust on the inside also and you wont know it. Most places do not want to recertify steel tanks.
ticki2 is offline   Reply With Quote
Old 07-10-2007, 06:24 PM   #26
1976 25' Caravanner
Stephen
Different regulations for horizontal tanks , I don't think they have an OPD valve for them . Check with a place that handles gases for welding and medical use they may know better. Or a Forklift dealer.
Old 07-10-2007, 06:42 PM   #27
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
My 06 classic has aluminum tanks. I beleive the safari's have steel.
Michelle TAC MT-0
Sarah, Snowball
Old 07-10-2007, 06:46 PM   #28
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
It was a Safari that I looked at with the steel tanks.
Bill
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
