Old 05-02-2016, 09:05 AM   #1
1964 24' Tradewind
Lawrence , Kansas
tank handle
So it was cold and raining and my tanks needed switching and the handle would not move so i tried harder and it broke off leaving me with a full tank and no handle. Can this be safely fixed and if not what does one do with the tank?
ttbikes is offline   Reply With Quote
Old 05-02-2016, 09:58 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
This is one I personally wouldn't touch. I'd take it to a propane dealer - Ferrell Gas or some regional company near you where they handle all the big tanks as well as the smaller RV ones.
Any company that converted the old standard valves to the OPD ones should be able to figure this out. Even if the tank is at end of life it's probably possible for a dealer to bleed it off safely. Definitely don't want a full tank thrown away!
Good luck in your search. BTW thanks to another tip on "cheapest propane" I found out that two local companies will fill my tanks while still ON the trailer rack. What a break - the Avion has 40 lb. tanks. WOOF!
Paula
Foiled Again is online now   Reply With Quote
Old 05-02-2016, 10:07 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Well that sucks.
There might be a small chance that you can get the valve open with some vice grips to use the propane up so that you will be able to replace the valve...
But since the valve was so stuck that the knob broke off, I wouldn't bet on vice grips working, but if it was my cylinder I would be inclined to try, a least in a minimal effort anyway.
Superat stultitia.
J. Morgan is online now   Reply With Quote
Old 05-02-2016, 10:24 AM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I was thinking exactly the same as "J.Morgan."
I would be inclined to give the threads a shot of penetrating oil, leave it a while then have at it with vicegrips on the valve stem in order to be able to use up the propane, the when empty, take to a dealer for a new valve.
If the vicegrips didn't do the trick I would just take it to the dealer "as is" to deal with!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-02-2016, 10:48 AM   #5
1964 24' Tradewind
Lawrence , Kansas
Thanks for the input. Tried vice grips but it is a no go. Sucker is really stuck. I called Heetco and they can fix it for about $30.00 (new valve and labor). Of course I loose 30 lbs. of propane.
Old 05-02-2016, 11:28 AM   #6
2016 25' Flying Cloud
Holly Springs , Mississippi
Are you positive the valve is closed? Just to test, use your ViceGrips and turn clockwise, as if to close the valve. If it won't turn in either direction, it's off to the propane store!
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 05-03-2016, 03:21 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
I suspect that the valve is open but the excess flow valve has tripped. It doesn't really matter much. The right thing to do is take it to a dealer. If the rest of the valve is working properly, the valve will close when the hose is removed, and then the tank can be bled down in a safe location through the bleed valve, and the valve can be replaced.
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Main water tank handle broken... 3campers General Repair Forum 0 10-12-2012 01:43 PM
'87 Excella gray water tank release t-handle? PA BAMBI II Waste Systems, Tanks & Totes 3 08-19-2010 06:03 AM
Auxiliary tank dump valve plastic handle replacements pageclot Waste Systems, Tanks & Totes 1 07-18-2009 05:42 PM
cleaning up toilet tank release handle cindy Sinks, Showers & Toilets 0 10-19-2002 11:44 AM
