Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 10-13-2009, 06:31 PM   #1
Profile:  Costa Mesa , California
System Regulators
I am in the process of building a new propane system in my rig, a 1955 which I purchased as an empty shell. The only question I have not found a consistent answer to is relating to the appliance regulators.
If all four appliances call to be regulated individually at 11"wc, do I still need a regulator from the tank to the main gas line? I have seen yes, and I have seen no. But in my head, it seems a redundancy that would inhibit the required cfm flow...
What is the accepted SOP when it comes to regulators?
Thanks!
Maxson is offline   Reply With Quote
Old 10-13-2009, 06:36 PM   #2
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The one regulator to the main gas line is all you need.
Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties. Oscar Levant
Old 10-13-2009, 06:41 PM   #3
Thanks, I was thinking that it makes sense that way, however was concerned how the appliances each called for individual regulators....
Old 10-13-2009, 07:07 PM   #4
1967 24' Tradewind
Images: 32
Individual would be very strange. Could it be that the appliances specified the pressure and you assumed that they meant individual regulators? The pressure is the same for them all. It seems like just some spec, like 120vac or 12vdc.
The good news is that it is cheaper as well as simpler.
However, you will want to find one that will automatically switch from one tank when it empties to the other (hopefully) full tank to avoid interruption of "service." Here is one source so you can see what I am talking about: http://www.vintagetrailersupply.com/..._p/vts-372.htm. There are others. I have bought here for other things, though.
Vaughan
propane regulator
Need help with my solar system... cclarkego Generators & Solar Power 39 08-09-2009 01:48 PM
Are LP regulators adjustable? gparker LP Gas, Piping, Tanks & Regulators 9 01-22-2007 02:51 PM
Propane connects and regulators. raebaker06 Repairing/Replacing Floor &/or Frame 1 01-05-2005 12:40 PM
lpg regulators gjohnson Parts Archive 2 06-17-2003 11:26 PM
