Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 08-16-2018, 01:28 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Switchover Regulator - Is this normal?
When I bought my Classic 30 Slideout 2 years ago I went to refill one of the propane tanks. As I had done with my Safari 25, I set the valve to the other tank, pulled the empty tank and had it refilled. When I disconnected the hose from the empty Classic 30 tank, there was a steady hiss of propane coming out of the hose. I had to turn off the other tank to stop it. I thought this was wrong, so I replaced the regulator. If I tested the new one, I don't remember the result.
A few days ago I wanted to pull a tank to get it refilled. Same problem on the new regulator. Am I mistaken that I should be able to set the valve to the other tank and disconnect the empty tank?
Al
Old 08-16-2018, 01:53 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
No, not normal, but, perhaps not unusual. Try tapping lightly on the regulator.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 08-16-2018, 03:15 PM   #3
Thanks. I found the manufacturer and they say I should be able to disconnect the empty tank without leaks. The regulator has a 5 year warranty, but I bought it from Amazon. This is one of those things where the manufacturer will not honor a warranty from Amazon. It was a hassle to find out who the seller was as they quit selling them on Amazon and the current listed seller is not the one I bought it from. After digging around on the Amazon website I finally found out how to speak to customer service. They put me in touch with the original seller and a new regulator is on the way. It was a hassle, but at least there is a happy ending.
Al
Flame King Auto Switchover Regulator Cissell LP Gas, Piping, Tanks & Regulators 4 01-13-2019 10:13 AM
Main power switchover system stevelou Airstream Motorhome Forums 6 07-21-2014 07:24 PM
110V Switchover Box kmamedia Land Yacht/Legacy Motorhomes 33 11-02-2013 05:52 AM
Propane tank switchover didn't indicate... Skater LP Gas, Piping, Tanks & Regulators 25 01-11-2012 05:41 PM
LP tank switchover Silvertwinkie LP Gas, Piping, Tanks & Regulators 6 03-12-2003 05:20 PM
