Old 03-30-2015, 04:05 PM   #1
Jim & Mitzi's Avatar
1990 34' Excella
1990 29' Land Yacht
Americus , Also Valrico, Fl
Suburban NT 34 Propane furnace
Recently bought a Avion 34' with above furnace in it. Furnace does nothing, so far. Spent most of day chasing wires ( 12V ) to find there is 12v to the furnace plug on the side of cabinet. The blower does not even come on. According to several Suburban wiring diagrams there is a OFF / ON switch within the furnace cabinet. I would assume it as accessible from the outside and furnace does not have to be removed to operate the switch. H e l p Is there such a switch and where is it ? In advance, many thanx for the support.
Jim & Mitzi is offline   Reply With Quote
Old 03-30-2015, 04:31 PM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
My original ('82) nt series furnace did not have an "on-off) switch, my new nt series furnace does and its near the wire connector. So very well may depend on the year of the furnace as to the on-off sw. If youve got 12volts to the furnace and the thermostat is calling for heat, the blower should kick on immediately for about 30 sec before it tries to light. If the blower isnt kicking on then you will need to determine if its a blower issue or control board. Either one will require you to remove the furnace. It does slide out from inside its metal housing but usually a real pita to get to. Good luck!
mayco is offline   Reply With Quote
Old 03-30-2015, 05:16 PM   #3
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Not the same suburban furnace but maybe the info in this manual will help. I know in our Suburban DynaTrail furnace the issue was the solenoid was loose and the thermo couple was dirty
http://www.airforums.com/forums/f427...al-131134.html
and
http://www.airforums.com/forums/f427...er-131137.html
Hope this may help some :-)
thesignlady is offline   Reply With Quote
Old 03-30-2015, 06:06 PM   #4
1976 27' Overlander
Delta , British Columbia
Furnace
One of the quickest things you can do is bypass the thermostat. When I bought my 76 Overlander the thermostat was not closing the circuit. Depending on your ability, remove the two wires going into the back of the thermostat, and touch them together with a jumper. Closing this circuit will send the start up signal to the furnace. Both of my t-stats were broken (furnance and catalytic heater). The new suburban ones are about $20 / each.
Good luck, hope it is as simple for you as it was for me.
Seabloom is offline   Reply With Quote
Old 03-30-2015, 07:08 PM   #5
1990 34' Excella
1990 29' Land Yacht
Not the news I had hoped for. :-). But I will pursue as U suggest. Many Thanx....at least it's spring..
Old 03-30-2015, 07:11 PM   #6
1990 34' Excella
1990 29' Land Yacht
Thanx to all responders. I think the wisest move is remove the furnace, clean it up, lube appropriately and find the fault. Again. Thanx.
Suburban Furnace recall !!! NewStreamer Furnaces, Heaters, Fireplaces & Air Conditioning 34 11-26-2015 03:29 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 12:36 PM
Suburban Furnace tmeagle1 Furnaces, Heaters, Fireplaces & Air Conditioning 25 02-20-2004 07:18 AM
Need Suburban Furnace Cover For 79/31' Soverign montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-29-2002 10:54 AM
