12-04-2015, 04:00 PM
2016 26' Flying Cloud
1988 32' Excella
anchorage
, Alaska
Sturgis regulator recall
Here is the replacement Cavagna regulator sent to us to replace the recalled Sturgis. We are in a very rural situation here and are trying to do this ourselves...So, how do we get these pigtails attached? It looks like the connectors that are on the regulator at the inflow ports are glued in ...waiting for a call from Sturgis on Monday, but hoping someone here can shed some light for a couple of un-mechanical people...
12-04-2015, 04:13 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I think that paper tag has some info for you.
One tank goes to each side and the supply line to your appliances goes to the bottom port.
2019 Ford Expedition Platinum
12-04-2015, 04:23 PM
2016 30' Flying Cloud
Oviedo
The regulator (as all retail regulators) have 1/4" inverse flare adapters semi-permanently attached. Airstream, unlike everyone else in the RV industry, uses 1/4" NPT pigtails. You can either try to remove the flare adapters on the regulator ( good luck with this) or buy new pigtails with the necessary male inverse flare connectors.
The guy at Sturgis probably forgot that Airstream uses an OEM part without the flare adapters.
My suggestion is to order the pigtails - you will be aligned with the rest of the RV industry and will have a much easier time with replacements in the future
Keith
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
12-04-2015, 04:25 PM
Naples
If you don't need the bushings at the inlet ports, they can be easily removed with a bit of effort. I usually place the regulator in a vise and use the appropriate sized wrench . It's not a glue, but a thread sealer compound.
lewster
12-04-2015, 04:27 PM
1988 32' Excella
anchorage
, Alaska
Thanks khollister...you are amazing with your knowledge...can I have you on retainer for future problems??!
12-04-2015, 04:29 PM
Oviedo
LOL - I'll be glad to take retainer and create a problem any time you need one. Wait ... I'm guessing that wasn't what you meant? 😳
Keith
Keith & Barb
12-04-2015, 04:37 PM
Oviedo
Lew has clearly had better luck removing the flare bushings than the one time I tried it. I swear they put them in with Locktite stud and bearing mount. A little heat is normally the ticket but that will likely screw up the regulator.
It's worth a try at least - removing them, not using heat
BTW - NPT (National Pipe Thread) connections require Teflon tape or thread sealant rated for LPG. Flare connections should be assembled bare. The outlet of the regulator is 3/8" NPT, so that needs tape - be sure to get the yellow stuff for gas.
Keith
Keith & Barb
12-04-2015, 04:41 PM
Naples
Keith
Nope, never had a problem, but then I have probably replaced over 50 by this point over the last 15 years.
lewster
12-04-2015, 04:49 PM
1988 32' Excella
anchorage
, Alaska
I just found the 1/4 inverse flare pigtails on Amazon and they will be here Monday, just in time for our road trip from GA to Texas next week with the new AS! Funny how AS is just a little bit different from the standard in the rest of the industry...We were traveling through Yukon Territory once and had a loose wheel which caused lug bolts to shear off. That little adventure had us spending an extra 5 days in Whitehorse, as we found out that the AS lug bolts are just slightly different from EVERYONE else! It's an adventure out there...
