A gas regulator should not freeze or stick, even at well below freezing temps. Is this the 1970 OEM regulator? I would replace it.
I guess it is also possible you have moisture in your lines, tanks or regulator.
In extreme cold it is also possible for the tank to freeze with very high gas flow. I had this problem when operating a kiln at below zero temps. However, I don't think that is your situation.
Pay no attention to the man behind the curtain- WoZ
