Old 11-05-2005, 06:22 PM   #1
JimGolden's Avatar
1977 31' Excella 500
Steel vs. Aluminum
Hi Everybody,
I'm fixing up a '77 Excella. The place I bought it from stripped a lot of stuff off it, and one of the things taken were the LP bottles.
I'd like to get aluminum bottles, but the prices for them are pretty high. The best prices I've found anywhere were at the airstreamdreams website. I think they were in the $150 range. The best I could do locally on the same tanks (Worthingtons...I haven't seen any other brand of aluminum tanks) was $240.
I've seen steel tanks for $79 (I'm looking at 40 pound tanks).
So the question is: Steel tanks for $79 and paint them with chrome paint, or bit the bullet and get the aluminum ones.
Other than appearance, is the aluminum so much better that they're worth double the money?
JimGolden is offline   Reply With Quote
Old 11-05-2005, 06:30 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Jim,
Aluminum tanks are substantially lighter in weight when full, and you don't have to worry about constant touch up painting. I have had both and much prefer the aluminum. IMHO they are basically maintenance free.
Aaron
WBCCI #XXXX AIR #2495
Old 11-05-2005, 06:55 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
As an owner of a '77 Excella 500 with 40 lb. aluminum tanks, I'd have to say go aluminum. They are so much easier to handle full as compared to the steel 40 lb. tanks. The tongue weight is over 1000 lbs. on my trailer so the aluminum tanks come in handy. In 4 years I have yet to clean the tanks. Rain just washes them off.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 11-05-2005, 09:20 PM   #4
1960 24' Tradewind
Riverside , California
Jim;
Steel tanks have to be re-certified every 12 years (not sure that's an issue), aluminum tanks do not....and they weigh alot less full and feather weight empty!
Greg
ZoomZoom is offline   Reply With Quote
Old 11-05-2005, 09:47 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Another vote for aluminum here...
I travel alone sometimes...not sure I could lift a full 40lb steel tank...we have 2-20's and even they are heavy when full.
Shari
Old 11-05-2005, 10:59 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by ZoomZoom
Jim;
Greg
Just a quick FYI, steel tanks have to be recertified after 12 years, then every 6 years thereafter.
And aluminum is so shiny when you polish it!
Old 11-05-2005, 11:08 PM   #7
InsideOut's Avatar
1956 22' Safari
Images: 108
Okay, they say a picture is worth a thousand words:
Left - Old Steel (painted silver)
Middle - New Unplolished Aluminum
Right - New Polished Aluminum
Shari
Old 11-06-2005, 01:23 AM   #8
_
another way to think about it.....
except for cost factors is there EVER a reason to choose steel instead of aluminum?
.........hum.........maybe if one planned to paint the tanks some wild colors/artsy fartsy design or have them chrome'd........
any other reasons to favor steel?
cheers
2air'
Old 11-06-2005, 05:27 AM   #9
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
yup,
aluminum tanks don't spark after falling off and hitting the pavement at speed!
i use steel tanks because they are cheap and plentiful. also, i have a tank cover on my trailer so i can't see them.
john
you call them ferrets, i call them weasels.
Old 11-06-2005, 09:11 AM   #10
InsideOut's Avatar
1956 22' Safari
Images: 108
Okay so there's one...
except for cost factors is there EVER a reason to choose steel instead of aluminum?<snip>
any other reasons to favor steel?'
Originally Posted by john hd
...i have a tank cover on my trailer so i can't see them.
But they are still heavier to manipulate when full.
Shari
Old 11-06-2005, 09:15 AM   #11
JimGolden's Avatar
Aluminum It Shall Be...
OK, I'm convinced. Aluminum it shall be.
Thanks!
Old 11-15-2005, 12:18 PM   #12
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
So aluminum tanks never need certification? I did not know that. Why would they be different than steel? I would assume both expand and contract. Or is it the rust thing?
>>>>>>>>>>>>>Action
Old 11-15-2005, 12:27 PM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
>>>>>>>>>>>>>Action
That is not what I've heard...as far as I can find ALL vertical vapor feed tanks need to be recertified every 12 years. With no exceptions. Another interesting item is that the OPD's are CODE not LAW however local enities...ie; states can make the code law....
Aaron
Old 11-15-2005, 02:08 PM   #14
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Regarding OPD's, I know I may be flying against the rules on that one. However I am convinced that the places I fill my tanks at are extremely skilled. And I am willing to bet my saftey on that, and, well, ..... I do.
However the above statements on al. tanks lead me to believe that they do not require recertification. Just looking for clarification. Cause my steel tanks will be coming up in several years and I will switch to the al. tanks if they do not need inspecting. (I am all for getting less complex) And the al tanks look better too.
>>>>>>>>>>>>>>Action
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Stripping paint off aluminum tin can luv General Interior Topics 4 04-18-2004 09:32 PM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
