Old 06-24-2013, 01:30 PM   #1
1972 31' Sovereign
Orangeville , Ontario
Source for flexible LPS tubing
Hello all:
We can't seem to source the grey flexible tubing that you can see in the picture between the two aluminum propane tanks. We live in Ontario Canada and our trailer is a 1972 30' Sovereign.
Anyone know where we can get this part?
Lori
Loripep is offline   Reply With Quote
Old 06-24-2013, 01:41 PM   #2
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Is that the connection between the regulator and the hard gas line into the trailer? If so, remove it - it should have a nut at each end, and take it to an RV supply house, or propane supplier for a replacement. A hardware store may have it as well. Match the length. However, you'll want a rubber one, like newer trailers have. Those old metal hoses would get brittle and crack from vibration.
robert claus is offline   Reply With Quote
Old 06-25-2013, 06:05 AM   #3
1972 31' Sovereign
Yes, Robert. It's the connection between the regulator and the hard gas line into the trailer. My husband says the problem is finding a diameter that will fit the original end pieces. We will replace with a rubber one as you have suggested. Thank you,
Lori
