Old 07-21-2007, 07:15 PM   #1
lewster's Avatar
Naples, FL , Hood River, OR
Solving the Equal-I-Zer/LP Dilemna
With all of the Equal-I-Zers out there that were installed improperly....that is.....with the bottom bolt placed incorrectly UNDER the LP line instead of BETWEEN THE LP LINE AND THE FRAME.......here is a step-by-step to re-do what the installer didn't do correctly!
I had the opportunity last week to correct a member's install job and took some shots during the fix.
1. Here it is as the dealer installed it:
Old 07-21-2007, 07:21 PM   #2
lewster's Avatar
Part 2
Note how the bottom bolt from the bracket is UNDER the LP line.......VERY BAD!!!!!!!!!
Now, remove the bracket and you will notice 3 P-clamps wrapped around the LP line with rubber insulators. Drill all 3 out of their respective rivets (note, some might be screwed into the frame, some might be riveted and some might have a combination of both like this 19CCD had).
This will loosen the LP line and allow it to droop.
Old 07-21-2007, 07:29 PM   #3
lewster's Avatar
Part 3
Now, with the LP line free to move a little from the frame, re-install the Equal-i-Zer bracket in it's proper position.
It's also a good idea here to add a little heat shrink tape to the bottom bolt before sliding that bottom bolt into the bracket. ust a little cushioning for that LP line.
Old 07-21-2007, 07:31 PM   #4
lewster's Avatar
Part 4
Now, re-rivet/screw/fasten the LP line back where it was attached to the frame
Old 07-21-2007, 07:32 PM   #5
lewster's Avatar
Part 5
And here is what the final job should look like:
Old 07-21-2007, 08:16 PM   #6
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Great job!
Thanks Lew
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 07-21-2007, 09:33 PM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Beautiful work!
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 07-22-2007, 01:37 AM   #8
JDL
JDL's Avatar
2005 19' International CCD
T , Oregon
Nice work! and great pictures!
JDL is offline   Reply With Quote
Old 07-22-2007, 08:24 AM   #9
richinny's Avatar
2011 34' Classic
if you don't have tape, a piece of rubber hose works nicely too!
Load distribution hitches-an analysis nickcrowhurst Hitches, Couplers & Balls 92 03-15-2010 06:41 PM
Basic LED questions Boondocker Lights - Interior & Exterior 17 04-12-2007 09:25 PM
One Elec Brake not Equal to Other Three wingfoot321 Brakes & Brake Controllers 1 04-24-2004 03:01 AM
"_Balancing Tires_" Silvertwinky Tires 15 02-22-2004 11:33 AM
LPG furnace vs elec. space htr. Astrodokk Airstream Motorhome Forums 4 06-25-2003 08:11 PM
