Last outing I noticed a propane smell coming from the tanks. Everything is original to the AS. 1985. And assume it's probably time to replace a few things. The propane hoses are both very stiff and I'll bet should be replaced.
Where can I buy pigtail propane hose connectors? I see them on Amazon for around 10 bucks each and I assume the connections are universal so they should fit my current set up. I'm guessing then I just need to buy the correct length?
I hope this will eliminate the leaking propane ... but if not I'm thinking of replacing the automatic dual tank changeover lp propane regulator. Here's where I need your experience. I've spotted a few online and need one with the sight gauge. But which ones will work and what should I steer clear of?
This one looks like it will do the job:
https://www.amazon.com/dp/B00KPR9Q30...J97D3ARKX9KRZK
Thanks, Mark
