Old 04-23-2016, 11:17 AM   #1
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
SHUT OFF the Propane at the tanks - OR NOT?
We've recently taken a couple of back-to-back short trips and simply left the propane valves open at the tanks. No having to purge air from the lines, Frige and Hot Water and Stove burners start right up.
So how dangerous is this?
Are the valves at the appliance end sufficiently robust to handle the constant pressure?
Does propane leak when the appliances aren't used for 5-10 days?
What do others do?
I would think full-timers generally leave the valves open for extended periods. True?
Observations, cautions, suggestions welcomed.
The Ice Man is offline   Reply With Quote
Old 04-23-2016, 11:31 AM   #2
Tincampers's Avatar
Sneedville , Tennessee
I only turn mine off when refilling the tanks or if we are boarding a ferry or a tunnel that requires them to be off. We fulltime.
Tincampers is offline   Reply With Quote
Old 04-23-2016, 11:34 AM   #3
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I full time, so I'm around to catch a whiff o' propane on occasion.
The only time I would get the smell inside is when I run the pilot light on the oven and the tank goes empty. Flame dies and what little pressure in the tank that is left will flow a bit of the gas & smell.
I would turn them off, when not in use. No air will get in, no need to purge, until you remove to refill a tank.
I only have one open at a time, I ran myself out of gas one time letting the auto changeover happen without me checking on the green stripe.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 04-23-2016, 11:41 AM   #4
Lily&Me's Avatar
Normal , Illinois
Mine is open all season, but when getting a refill.
Maggie
Old 04-23-2016, 12:14 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We leave them open all year. If there are any leaks in the fittings, valves, or lines anywhere is the system they should be found and repaired.
Doug and Cheryl
Old 04-23-2016, 12:14 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Been on for 25 years except when refilling, fretting, or where required by law.
Old 04-23-2016, 01:33 PM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
That sounds about right.
Now that said I did have a period when I was losing a bit more gas than i should have. Turns out the flared nut on the hose from the tank to the copper piping at the tongue had vibrated loose. Never enouth to smell just enouth to lose some gas while the trailer was stored.
So maybe once a year turn them off when you expect to be away from the trailer for weeks or more. When you turn the tanks back on if you hear any gas flow that will test the system for leaks.
The valves in the appliances should never leak.
2004 Excursion 4x4
Old 04-23-2016, 01:35 PM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Should read ferrying......
Old 04-23-2016, 01:36 PM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Leave them on, and leave the fridge on as well, unless you are refilling the LP or TV fuel tanks. Then, shut the fridge off, and restart it after you move away from the pumps. Personally, I feel my chance of there being a problem caused by leaving the tanks/fridge on is much lower than my chance of getting food poisoning from the stuff in the fridge getting a little too warm.
And one of our customers was involved in a serious accident with his Airstream, and the open LP tanks did not cause a problem.
Old 04-23-2016, 01:41 PM   #10
HowieE's Avatar
Images: 12
That is a Coast Guard regulation that applies to anything stored in a ship hole.
On the 17 hour ferry from Port Hardy Vancouver Island to Prince Rupert we froze a couple of soda bottles the day before and they held the frig for the trip.
2004 Excursion 4x4
Old 04-23-2016, 02:01 PM   #11
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I keep my tanks turned off when at home. Never really had any trouble restarting appliances. I have never turned my gas off when refilling gasoline or going thru tunnels. Never had the trailer on a ferry so will cross that bridge when I come to it.
MICHAEL
Old 04-23-2016, 03:05 PM   #12
2016 23' International
Salem , Oregon
Chief, thats the reason there is a ferry there as you don't have a bridge to cross.
Dave
NoResults is offline   Reply With Quote
Old 04-23-2016, 03:24 PM   #13
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Ditto.
( I caught your humor..... That was good....)
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
"I don't mean to sound degrading but with a face like that you got nothing to laugh about"
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 04-24-2016, 10:10 AM   #14
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
closed when not in use. The furthest gas fired appliance away from the source is the water heater and it fires right up when we set up.
kdickinson is offline   Reply With Quote
93 Hot Water Heater Propane Shut off Lumatic LP Gas, Piping, Tanks & Regulators 0 06-08-2015 11:19 AM
Propane auto shut off reset mayco LP Gas, Piping, Tanks & Regulators 2 09-30-2014 12:17 PM
Inline Propane Shut-off Valves?? SLNugget LP Gas, Piping, Tanks & Regulators 8 09-14-2012 10:52 AM
What temperature should the propane shut off? Getahobby Water Heaters, Filters & Pumps 2 08-19-2012 11:21 AM
When to shut off LP tanks moosetags LP Gas, Piping, Tanks & Regulators 27 08-11-2006 09:11 PM
