Old 12-31-2013, 10:04 AM   #1
1973 31' Sovereign
Santa Rosa , Texas
Sewage/ grey tank?
I have been removing the flooring of my 31' 73 sovereign. I noticed that there is a crack on the gray tank just below the toilet. I would like to order a new one before I put the flooring back. Does anyone know where I can order one from? Is that the only tank in the back?
Javier
AirStream73 is offline   Reply With Quote
Old 12-31-2013, 10:35 AM   #2
tony6373's Avatar
2000 28' Excella
1994 31' Legacy 30
Hillsboro , Texas
Tanks
The toilet tank is traditionally called the "black tank" and the wash water tank is called the gray tank. If your Airstream was built in 1973 it did not come from the factory with a gray tank... well there may have been a couple of overlap units built. 1974 was the first year of regular production with a gray tank and it was only 10 gallons.
Replacement tanks for the older models are usually not available and must be repaired (if possible) or a replacement tank can be custom built at considerable expense. Used tanks can sometimes be found but they are also old and the plastic tends to crack with age. There are universal replacements available in a limited range of sizes and shapes. Do a web search. Good luck.
Tony T
2000 28' Classic TT
1994 30' Land Yacht M/H
tony6373 is offline   Reply With Quote
Old 12-31-2013, 12:16 PM   #3
Javier
The black water tank for a 1973 Large size Airstream, is available.
