Old 11-12-2006, 09:26 AM   #1
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
See through propane tanks
Has anyone ever tried one of these tanks?
I found them for as low as $79.00. They are lighter than steel tanks,cheaper than aluminum and made in Tenn by the Lite Cylinder Co.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 11-12-2006, 09:30 AM   #2
hendrie42's Avatar
1968 20' Globetrotter
Albuquerque , New Mexico
wow i like those --------------
hendrie42 is offline   Reply With Quote
Old 11-12-2006, 09:40 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
They look really cool! With thoese colors, you could make a real fashion statement on the front of your Airstream.
SuEllyn & Brian McCabe
Old 11-12-2006, 09:50 AM   #4
Janet H's Avatar
1964 26' Overlander
Images: 90
How about blue? Anyone actually used one of these?
Old 11-12-2006, 09:54 AM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
wonder how they hold up in a fire?
or road debris such as a rock?
are they DOT approved?
john
you call them ferrets, i call them weasels.
Old 11-12-2006, 09:57 AM   #6
hendrie42's Avatar
do they come in silver ---------
Old 11-12-2006, 10:00 AM   #7
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
The fire test video was most impressive. It seems that the propane leaked out thru the tank skin and was burned, rather than blowing up. I wonder if the plastic cover that seems to be used over the composite tanks would affect the burn characteristics.
I wonder if the available 20 lb. tank is of the standard height and diameter of steel tanks or aluminium tanks. If not they may not fit properly on the trailer tongue and especially not under a tank cover. I wonder when a 30 lb. version will be available.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 11-12-2006, 10:07 AM   #8
Janet H's Avatar
1964 26' Overlander
Images: 90
I did some more digging... They are DOT approved and do come in a 33 LB version that can be used vertically or horizontally. The 20 lb seems to be standard size the 33 lb is designed for forklifts and chemical applications but can be used upright.
Old 11-12-2006, 10:17 AM   #9
moosetags's Avatar
I just looked the manufacture's website. These things could become all the rage in the RV community. Just think, you will finally know for sure how much LP is really left in that tank.
I noticed that the company is in Franklin, Tennessee. Maybe a member in the Nashville area can swing by there and check it out further.
Old 11-12-2006, 10:22 AM   #10
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Interesting idea. The only reason I personally wouldn't purchase them is because they won't polish as nicely as the aluminum tanks do!
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 11-12-2006, 10:40 AM   #11
NorCal Bambi's Avatar
1963 16' Bambi
Yreka , California
Images: 21
These tanks do look very interesting. Has anyone seen anything about expected livetime of the cylinders. Also expansion and contaction affects on live.
Don
NorCal Bambi is offline   Reply With Quote
Old 11-12-2006, 10:47 AM   #12
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
one would need to be careful with forklift tanks since they have a vapor and liquid valve.
could make for some interesting cooking sessions!
john
Old 11-12-2006, 10:55 AM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
We will probably have those answers tomorrow, as I emailed them for relevent info for our particular use.
Old 11-12-2006, 10:56 AM   #14
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
... The 20 lb seems to be standard size the 33 lb is designed for forklifts and chemical applications but can be used upright.
FWIW, forklift LPG cylinders use different gas fittings for connections than standard gas cylinders.
I don't much care for those see-through gas bottles ; What fun would camping be without wondering if you have enough gas to make it through the night?
Tom
« Gas leak? | Top | Tank rack »
propane tanks david h Our Community 5 01-12-2003 07:49 PM
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
Retrofitting Old Propane Tanks (non-opd) leslie LP Gas, Piping, Tanks & Regulators 18 09-20-2002 10:24 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
