Old 12-02-2003, 11:02 PM   #1
security for propane bottles
I have my 74 Tradewind stored in a fenced and locked facility--but--I am nervous about leaving my aluminum propane bottles on the trailer. I would prefer to leave them with the trailer. Is there a way of locking them to prevent theft? I was able to locate an aluminum Excella cover for the bottles--I will have to do a little metal work on the cover so that it will fit over the equalizer hitch brackets but I think it will work. Any suggestions about security or my attempt to alter the Excella cover to fit my tanks. The tanks are 30 pounds.
Shelby Copeland is offline   Reply With Quote
Old 12-02-2003, 11:42 PM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Why not just lock them inside the trailer?
Rog
Rog0525 is offline   Reply With Quote
Old 12-03-2003, 04:42 AM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
a long bicycle cable lock passed through the handles and around the frame would keep them in place.
some hardware stores will custom make such cables.
all you need then is a good padlock.
it can be removed and stored when your trailer is in more secure area.
john
you call them ferrets, i call them weasels.
Old 12-03-2003, 05:43 AM   #4
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Get a Yakima rack lock.
I used a threaded Yakima rack lock on min. it is keyed and can be threaded down the shaft so it will act as a jam nut on top of the spinner handle. If they want the bottles they will have to cut something that way, and it s unobtrusive. I think the locks come in a pack of 2 and the tumblers are sold individually. Your local large bike shop should stock them
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 12-03-2003, 06:54 AM   #5
Send a message via Yahoo to Fun-Lovin
It required a little work to do what I did. I first aligned the tanks in the base frame to the position they needed to be. Then on the base ring of the tank I drilled a hole and worked it with a dremel tool to get the correct size. This hole was matched to a hole I drilled in the base frame. Now I use a pair of master locks that only the top of the arch can be seen. The entire lock is under the propane tank. You would never know they were locked down.
Greg
1976 Soveriegn 31'
F250 Turbo 7.3L Diesel
WBCCI # 3516
Fun-Lovin is offline   Reply With Quote
Old 12-03-2003, 09:25 AM   #6
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
good idea
good idea on putting a lock below the tanks. I think I'll try that.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 12-03-2003, 12:28 PM   #7
overlander76's Avatar
Send a message via ICQ to overlander76 Send a message via AIM to overlander76 Send a message via Yahoo to overlander76
I have a nut on top of the threads and then there is a lock that covers the nut and locks. The lock just spins and the nut doesn't. It came on there when I bought it but someone could just cut the long bolt if they wanted to steel them. I would agree with the long bike cable lock idea or put them inside for safe keeping.
Brian
overlander76 is offline   Reply With Quote
Old 12-03-2003, 03:46 PM   #8
LLB21's Avatar
I have drilled a hole through the propane handle and put a bicycle lock through it. That way it cannot be turned to loosen it up.
It took one stolen propane bottle for me to do that. Seems like we are always one step behind the crooks!
Louie
LLB21 is offline   Reply With Quote
