Old 07-15-2004, 01:56 AM   #1
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Securing Aluminum Tanks
When aluminum tanks went on sale at Airstream Dreams I figured that was my cue to break down and buy a pair. They arrived the other day and I'm in the process of polishing them. How are folks securing their new, freshly polished tanks to the trailer to keep them where they belong? I'd sure hate to lose them..
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-15-2004, 04:19 AM   #2
Ann Arbor
FF
After having had my tanks come loose and dragging one for a few miles , I promptly bought four 19" black stretch cords, two for each tank. You can bet that tank security is one of the "pre-flight" checks I now routinely make. That includes the condition of the stretch cords. Not pretty, but effective.
Eugenie
maznblu is offline   Reply With Quote
Old 07-15-2004, 04:42 AM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
brad
you may be able to use the holes in the base ring to fashion a locking pin arrangement. it could pass through the ring on the tounge and the base ring on the tank.
would make a good out of sight anti theft device!
john
you call them ferrets, i call them weasels.
Old 07-15-2004, 05:55 AM   #4
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Brad,
You will need to verify the thread size but, when we full timed I used a Yakima threaded bolt lock. It was threaded on the hold down shaft and acted like a jam nut to the spinner handle. Once in place and locked it was going to be very difficult to remove it, or the bottles since I had pressure on them with the hold down. It was one extra key, but I did not have to worry that my 30 LB Aluminum tanks were going to get legs.....
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-15-2004, 07:35 AM   #5
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Brett,
That sounds like the solution I had in mind. Do you have a picture of this device in action on your trailer? An aluminum tank with legs would be a terrible sight...
FF
Old 07-15-2004, 09:14 AM   #6
1975 24' Argosy 24
Burlington , Ontario
On my 74 Argosy (22ft) there is a long shaft inbetween the tanks and a "T" bracket that is held down with a Nut. I have a threaded nut with a cover that when on and the locking key is removed allows the cover to turn free, and no access to the holding nut. I have seen several times , Marks on the edges of my tanks, but I still have them.
Believe it or not on my towing vehicle we had an old car cover, ....someone stole it. Blessings upon them because it was destined for the garbage.
raebaker06 is offline   Reply With Quote
Old 07-15-2004, 09:51 AM   #7
MW64OVERLANDER's Avatar
1964 26' Overlander
Norman , Oklahoma
Images: 67
Flyfshr,
When I replaced the old metal tanks on my 64 overlander with new polished alumimum tanks, I was also worried about the possibility of losing them. I had two concerns; the first was me failing to tighten the lock down bar after a propane refill and the second was a failure of the threaded rod that the lock down bar mounts to. I wanted a backup method that worked independently from the primary lock down hardware. The solution I came up with was found in the electrical section of Home Depot. It consists of a cad plated crows foot clamp and bolt that grips the cylinder mounting ring on the trailer frame with the crows foot and the bolt screws down and locks on the heavy aluminum ring that makes up the base of the tank. This arrangement locks the cylinder to the trailer mounting ring and gives a nice tidy backup solution. The clamp can be seen just below the cylinder in the following picture.
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
Old 07-15-2004, 10:28 PM   #8
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Mark,
Can you take a close-up of the device you described. There's a Home Depot right up the street
FF
Old 07-15-2004, 11:18 PM   #9
1964 26' Overlander
Norman , Oklahoma
Images: 67
Flyfshr,
I will blow up the picture I previously posted. I do not have a picture available of the clamp from a side view, but it is shaped like a "u" when viewed from the side and has a square headed bolt that threads in from the back side. You would actually tighten the bolt from under the cylinder.
Mark Wilson
Old 07-16-2004, 10:11 AM   #10
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
A word of caution for old trailer owners:
The hold down rod on my 1963 Overlander snapped right off at the base when I tried to undo the winged screw on teh top of the rod. Id did not look bad, and there was no evidence of corrosion near the bottom, just on the top where the winged nut got rusty on the treads.
My advice would be to replace this rod soon if you have not already done so.
Uwe
www.area63productions.com
Old 07-16-2004, 10:52 AM   #11
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Uwe!
I second the advice - - I had the same experience with both my '64 Overlander and '78 Minuet. The Minuet was well behaved, and this repair was required when removing tanks for filling while parked in my home driveway - - the one on the Overlander failed while in the wilds of South Dakota. Checking these brackets is now on my regular maintenance check-list.
Kevin
Kevin D. Allen
AIR #827
Old 07-18-2004, 12:51 PM   #12
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I use a 6' Kryptonite vinyl covered steel cable with a loop on each end. I run one end of the cable through the collars and then run that end through the loop on the other end. I then lock it to the connection the chains are attached to with a large stainless steel Master padlock. So far so good.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-18-2004, 01:17 PM   #13
JohnG's Avatar
It's unfortunate that the manufacturer of the aluminum tanks couldn't just put a ring at the bottom of the tank that has say 4 round holes in it so securing the tanks would be easy for anyone. I suppose one could have such a ring added to the bottom if you know a good welding shop.
On another note my local propane supplier has informed me that he is able to get steel tanks that are chromed. The cost is around $120 for a 30 pounder.
Anyone else have an outlet for these and do you think a chrome tank would be just as good as a polished aluminum tank?
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-18-2004, 01:25 PM   #14
davidz71's Avatar
1986 25' Sovereign
I have always heard that chroming or nickle plating certain auto parts will actually weaken them but they have nickle plated and hard chromed semi-auto pistol frames/slides for years to resist the weather as well as sweat from hands without ill effects. The bad part about chroming is that a single imperfection or nick will set up rust at the site and then you are done for. I would be more inclined to just re-polish from time to time to keep them looking good although my aluminum tanks are still in the buff.
Craig
AIR #0078
3.73 rear end
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
Another reason for aluminum tanks rochleau Our Community 4 09-03-2002 06:30 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
