Old 09-27-2015, 10:57 AM   #1
Clyde , North Carolina
seaLevel monitor system
Installed seaLevel monitor for grey, black, fresh, and battery. The monitor has a LPG monitor option/button but during install I didn't wire anything to monitor for LPG assuming my propane tanks didn't have senders. Since then I've noticed this White wire. Does that white wire look like anything related to propane monitoring?
Wycolo is offline   Reply With Quote
Old 09-27-2015, 10:59 AM   #2
Originally Posted by wycolo View Post
installed sealevel monitor for grey, black, fresh, and battery. The monitor has a lpg monitor option/button but during install i didn't wire anything to monitor for lpg assuming my propane tanks didn't have senders. Since then i've noticed this white wire. Does that white wire look like anything related to propane monitoring?
Name:	ImageUploadedByAirstream Forums1443373178.844116.jpg
Old 09-27-2015, 11:17 AM   #3
dznf0g's Avatar
Oswego , Illinois
No, that's a ground for something. If you had bottle level, you would see a needle gauge on the bottle top, with a wire attached to it.
-Rich-
Is it ever necessary to calibrate the new SeaLevel Tank Monitoring System? Hibby Waste Systems, Tanks & Totes 11 10-23-2014 05:28 AM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
Tank monitor system on the fritz mhilley Fresh Water Systems 7 11-27-2011 08:57 AM
System Monitor vs. Reality (black water)! tomorevam Waste Systems, Tanks & Totes 7 05-14-2011 02:59 PM
Upgrade to a new system monitor? GoNomad Electrical - Systems, Generators, Batteries & Solar 7 10-27-2006 07:02 AM
