Old 10-11-2011, 06:14 AM   #15
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I purchased/installed an Everpure filtration system which directs one to "superchlorinate" the fresh water holding tank. The filter, mounted under the kitchen sink, then removes that (plus other "problems").
While a filter (or system of same) attached to the fresh water inlet hose is good, I also wanted a method whereby the tank and plumbing were kept under treatment constantly. Just a couple of days of very hot weather can change things for the worse.
Old 10-11-2011, 07:06 AM   #16
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
So everpure is add sodium hypochlorite to you water and remove it at point of use with an activated carbon filter.
Darkspeed is offline   Reply With Quote
Old 10-11-2011, 08:27 PM   #17
reinergirl's Avatar
Hollis , New Hampshire
I was thinking that installing one of the clean out hatches mentioned in the post below would be an excellent decision.
http://www.airforums.com/forums/f443...tch-69584.html
Bleach is all well and good but a good scrub out IMHO is essential. Plus one can dry out the tank....
reinergirl is offline   Reply With Quote
Old 10-11-2011, 08:45 PM   #18
Darkspeed's Avatar
1972 31' Sovereign
The port is a good idea..
This is also another good idea..
Portable Purifier | Household Ozone Disinfection
Old 10-11-2011, 08:56 PM   #19
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I would offer simply filling the tank with treated municipal water is sufficient.
After all, one does not "flush" or sanitize the plumbing in ones' home.
Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-11-2011, 09:01 PM   #20
reinergirl's Avatar
I really like how you think "outside the box" but you may want to rethink this one. I actually took an ozone generator off an indoor hot tub because of reports that it was harmful to our lungs and respiratory systems.
I remember researching it at the time and thinking that the research showed more harm than good coming from ozone generators.
Here's just one site from the EPA.... Ozone Generators that are Sold as Air Cleaners | Indoor Air | US EPA
Old 10-11-2011, 09:52 PM   #21
Darkspeed's Avatar
1972 31' Sovereign
Iv actually worked with large quantities of ozone in a lab environment and you are correct at high levels it can be lethal but then so can sodium hypochlorite In small volumes, especially in an enclosed tank it should be fairly harmless. Good point though!
Old 10-12-2011, 07:26 AM   #22
dznf0g's Avatar
Oswego , Illinois
Regards,
Exactly! Finally! I sanitize once a year, in the spring after storage. Done it that way for 35 years. NEVER a sick family member. We drink it, do dishes with it......everything.
Old 10-12-2011, 08:04 AM   #23
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
We used to have a hot tub and until the ozone generator failed, it worked fine. After that it didn't work so well. But we didn't drink the water and it was mostly under a cover in the dark with temps around 104˚. It isn't a good analogy.
Another system we have is that our residential water is delivered on a dole system to 3,000 gallons of water storage. They are dark, but not hot. We have been advised to clean the cisterns annually with chlorine, but the chlorine in the water system does an adequate job. We have never cleaned the cisterns and we haven't gotten sick. We also have an activated carbon filter for the house.
We all want to prevent sickness and have to ask the question: how much protects us from reasonable risks? Probably all of these systems work well and how much is too much?
Gene
Old 10-12-2011, 12:58 PM   #24
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Regards,
One does when the city issues a "Must Boil" warning. Drought, floods, breaks, etc can happen and do.
A decent RV system that the owner maintains is just decent insurance. I'd rather not ever worry over it, thus the Everpure for me.
Old 10-12-2011, 01:23 PM   #25
jdalrymple's Avatar
Jay , Oklahoma
I agree that water systems occasionally have issues and must employ alternatives for sanitizing the water they supply.
But, when public systems are operating normally the provided water is treated to remain safe during transport throughout the system. Tap water added to my tank from a trusted source, in my case my home's plumbing and a garden hose reserved for the purpose at hand, is safe enough for me. Untreated well water, for instance, would give me pause.
My opinion is that the more sterile we attempt to make our lives, the less resistant to the "bugs" of the world we become. And, the stronger the bugs become. Not to say reasonable precautions should not be taken, but something to be considered none the less.
Just my thoughts.
Regards,
Jeff & Cindy
'91 350 LE MH
Old 10-12-2011, 01:45 PM   #26
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Just my thoughts.
Regards,
And mine are that when I am traveling I am far more vulnerable to problems that are easily handled at home, in a relative and absolute sense. It should not be disregarded that rural America suffers not only from a lack of medical personnel, but personnel of the same caliber as in the largest cities. Budget cuts and the rest of what is driving America out of First World status have immediate ramifications.
When I am at home I am surrounded by a support network that I do not have as a traveller.
Trusting that fruit and other foods that have passed FDA muster is enough of a gamble. The assumption of clean water does not pass the test any longer due to the consequences being greater if a problem occurs. "Privatization" of water supplies is practically a guarantee of problems not seen in this country for several generations.
We now live in an era where the answer to investigations uncovering fraud, waste and dangers is to remove the funding for such investigations. Imprisoning whistle-blowers is a more likely outcome than apprehending perpetrators, now.
Playing in the dirt, fine. Ingesting other than simply ordinary bacteria, no.
Old 10-12-2011, 03:01 PM   #27
dznf0g's Avatar
Oswego , Illinois
I understand the concern for sterilization if one has some overriding health concerns, but we should distinguish those concerns as the exception. Otherwise, we have newbies who will think it is necessary for ALL of us to panic about our FW tanks and systems. Fair enough?
Old 10-12-2011, 04:47 PM   #28
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Perhaps I been lucky during 40+ years of RVing, but this is what I do.
After every trip I empty the tank.
Before every trip I fill the tank.
If I put some questionable water in the tank during a trip, I flush it with home water after I drain it.
If it has been sitting for a long time since the last trip, I flush it before I fill it.
My theory, which seems to work fine, is that there is enough chlorine in our tap water to deal with whatever might be in the little amount of water left in the tank after it is drained.
Yes,
We drink the water. I even open my mouth in the shower once in a while.
Yes,
I did get Giardia once, but I know where it came from, and it wasn't the trailer tank.
Ken
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 02:39 PM
Black water flush system mjayjensen Waste Systems, Tanks & Totes 4 07-10-2011 05:21 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
Sparkling Water System wrochdvm Plumbing - Systems & Fixtures 0 05-10-2011 04:38 AM
