Old 06-30-2007, 08:39 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Running propane lines
I guess I should have asked this BEFORE I spent all day running propane lines under the trailer.
I recently had my leaf spring axles swapped over to torsion. I have enough clearence to run my 1/2" copper main feed down the center of the trailer above the axle beams with less then 1/8" clearence. They are tied up and not touching it.
Now the question. The axle beam should not move up and down releative to the trailer, right? Am I in danger of smashing my lines while going down the road?
Like I said, I should have asked before... its all done now .
I did not have a nice enough pipe bender to go under the axles, thats why I went over.
-Tim
theVAP - Airstream Podcast
Old 06-30-2007, 09:07 PM   #2
Images: 59
I think you should also be concerned about the floor flexing and squishing the tube from above.
Run a piece of steel on either side of the tube where it crosses the axle to keep it from getting squashed.
Old 06-30-2007, 09:41 PM   #3
Images: 59
Second thoughts. The floor might flex more than 1/8", but it would be between the crossmembers and there is nothing to squish the tube against except the belly pan skin.
If the tube crosses the axle tube where there is a crossmember, it is unlikely the floor would flex enough to squash the tube.
Will the axle tube bend 1/8"? I don't know.
Old 06-30-2007, 11:25 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Use black pipe for the main truck line, never worry about it.
'77 Sovereign Intl 31' CB
Old 07-01-2007, 01:47 AM   #5
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Don't worry, this is a stock arrangement in some AS out there. I know some people put a slice of rubber hose around them just to save them from potiental shafing, but you should be fine. That axle beam does not move.
Marc
Old 07-01-2007, 04:38 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
A sleeve made out of rubber hose or PVC is
f you can get it slipped over. FWIW mine run between the axle and the belly pan on my '75 and '80. Mine are original and all copper. I plan to run all new lines just because. Don't want to use the black pipe, I have had problems with them cracking at the threads and fittings on an SOB before.
Aaron
WBCCI #XXXX AIR #2495
Old 07-01-2007, 03:23 PM   #7
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thanks everyone. I feel much better now :-)...
-Tim
Old 07-01-2007, 03:45 PM   #8
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I would not sleeve a copper gas line. You are creating a sitation where water can be trapped and cause the line to corrode and eventually leak.
Michelle TAC MT-0
Sarah, Snowball
new water lines Rob Fresh Water Systems 29 07-11-2006 08:25 PM
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
