Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 10-08-2009, 12:18 PM   #1
Profile:  1964 24' Tradewind
Orlando , Florida
Running new LP gas lines
Im a little confused and seem to be finding contradicting information, hopefully someone can help. While rebuilding my 64 tradewind, I am going to be running all new LP lines. The current lines have been removed so I cant just retrace the old lines. I have the original diagrams from the owners manual and I know where my new range, fridge, water heater etc will be placed,so I know the general path that they will take.
My first question is "where do the lines run?" Above the subfloor, between the subfloor and belly pan, or under the belly pan?
My second question is "what do I use for the lines?" Copper? is there a flexible line that can be used?
Thank you for your help and clarification in this matter. You will truly be a help for me.
photocodo
photocodo is offline   Reply With Quote
Old 10-08-2009, 12:29 PM   #2
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
Coil copper and double flare fittings is as safe as you can get - all lines on exterior belly panels until the stub in to the fed appliance for safety reasons - exact routing is open for discussion - armoring the bare copper with garden hose or other impact absorbing shell material is often used...
Powered by Tinnitus
Parkside Logic - My Site & Blog
Old 10-08-2009, 01:01 PM   #3
Profile:  1968 24' Tradewind
Oxford, , Mississippi
I have a 68 TW. A "trunk" line runs down the middle of my trailer with t-fittings for smaller lines to each appliance. The lines are held to the bottom of the belly pan with pieces of aluminum folded around the copper and riveted to the belly pan. Very simple but it has worked for 41 years on my trailer.
Old 10-08-2009, 01:10 PM   #4
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Do not route the lines inside the trailer, or in between the floor and the belly skins. In the event of a leak you'll want to minimize the chance of any vapor build up in enclosed spaces.
We have a steel pipe trunk line that ends with a Tee connection. The copper feeders come off the Tee routing to the various appliances.
Use copper with flare connections, and mount the copper tubing to the roadside of the belly skin with rubber padded holders to prevent chaffing.
Regards,
Kevin
Experience can be a difficult teacher...You usually get the lesson first...And the instruction afterwards...
Kevin245 is online now   Reply With Quote
Old 10-08-2009, 01:27 PM   #5
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
The routing along the underside of the belly pan is your choice. Just pick whatever suits your needs. Make sure you use 1/2 in piping for the trunk line and branch off that with 3/8 to feed individual appliances.
While bare soft copper is used in most manufacturing there is a yellow covered copper designed for burial that you may want to consider since the lines under the trailer will be exposed to weather.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 10-08-2009, 02:01 PM   #6
Calgary , Alberta
We have the same trailer and it's mostly intact. Next time we visit it I can have hubby try to examine and describe or photograph the locations of the lines for you. I think we will be replacing the gas lines in ours simply because I don't have much trust in gas lines that old.
Blanchard is offline   Reply With Quote
Old 10-08-2009, 06:07 PM   #7
I forgot to say but HowieE mentioned, 1/2 in trunk line and 3/8 feeders. Also, and it goes without saying, make sure you put a proper shut off valve for each appliance. All the original lines are just single flare and the tubing is just plain copper. Single flare tools are much cheaper to buy than the tool to make double flares. As I stated earlier, after 41 years of exposure under the belly pan and mine is still OK and have no major corrosion.
Old 10-09-2009, 02:15 PM   #8
Wabbiteer's Avatar
1972 29' Ambassador
Originally Posted by 68 TWind View Post
Also, and it goes without saying, make sure you put a proper shut off valve for each appliance...
Amen. Thanks 68 TWind for catching that...
Powered by Tinnitus
Old 10-08-2009, 06:12 PM   #9
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
My SOB trailers have used black iron pipe for the trunk, and then tees for the branch lines with copper flair fittings. Seems to me the more solid pipe (copper or black iron) would be better for the main trunk line? And then use the flexible copper for the branches. Thoughts?
Old 10-09-2009, 07:32 AM   #10
Kevin245's Avatar
Here are some pictures of our Avion for reference. Our AS has a copper trunk line that runs nearer to the curb side instead of down the centerline.
Kevin
ID:	88606   Click image for larger version
Old 10-10-2009, 08:24 AM   #11
Orlando , Florida
Kevin
It looks to me that you used straight copper pipe as the trunk line and then coil copper lines coming directly from the trunk line to inside the unit. Is that the case? if so is that acceptable, it seems like it would be easier to get the pipe into the unit that way. Is the coil copper softer? does that get damaged any easier while on the road? thanks
photocodo
Old 10-10-2009, 11:10 AM   #12
Kevin245's Avatar
photocodo
The trunk line is actually steel. The feeders coming off the tee are copper. The advantge to the coil copper tubing is that it is softer then the hard pipe copper, and it does give should something strike it. Ours does have a few dings in it from years of towing, but there are no leaks.
Regards,
Kevin
Old 10-09-2009, 03:20 PM   #13
Distantdrummer's Avatar
Profile:  1975 31' Sovereign
, various
I was not aware of "double flaring" I am searching for illustrated info on same.
And pix of the tools and procedures to do it. Anyone have links to that kind of info?
I think I would stub out a double connector curbside for plugging in hoses to a grill, an outdoor space heater, or a fry stand, a pear burner (fire-starter) etc.
Or maybe better to install a double stub connector near the bottles on tongue?
And yes a quarter turn cut-off valve behind the stub-out.
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 10-09-2009, 04:21 PM   #14
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
google "double flare"
double flare - Google Images
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
richinny is online now   Reply With Quote
LP Gas Lines Silverhobby All Argosy Trailers 6 01-24-2008 10:25 PM
Running propane lines Safari Tim LP Gas, Piping, Tanks & Regulators 7 07-01-2007 04:45 PM
Replacing Gas Lines? Frostyone LP Gas, Piping, Tanks & Regulators 2 05-14-2006 10:21 PM
gas lines scootertrash LP Gas, Piping, Tanks & Regulators 1 02-27-2003 11:00 AM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 02:06 PM
