Old 10-09-2009, 04:25 PM   #15
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Keep is simple. Use the proven time tested method and you will be fine. Do check each tee and valve for leaks, goes without saying.
Old 10-09-2009, 04:28 PM   #16
HowieE's Avatar
Princeton , New Jersey
Images: 12
The best leak detector I have found is Simple Green in about a 1 to 3 ratio. It foams with the smallest leak rather than blowing a larger bubble that can be broken in the wind.
2004 Excursion 4x4
Old 10-09-2009, 04:36 PM   #17
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Ok - I did say M with a question mark - then its sch K - obviously I can't remember which one, but I know there is one for gas...
I used double flairs - seems to be ok
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 10-09-2009, 08:16 PM   #18
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I redid the main line with black pipe, branching off with copper.
I looked at all the new SOB's that's the way they do it.
I then covered the copper with clear vinyl tubing to help protect from rocks and other debris.
'77 Sovereign Intl 31' CB
Old 10-10-2009, 07:24 AM   #19
1964 24' Tradewind
Orlando , Florida
Originally Posted by Kevin245 View Post
Here are some pictures of our Avion for reference. Our AS has a copper trunk line that runs nearer to the curb side instead of down the centerline.
Kevin
It looks to me that you used straight copper pipe as the trunk line and then coil copper lines coming directly from the trunk line to inside the unit. Is that the case? if so is that acceptable, it seems like it would be easier to get the pipe into the unit that way. Is the coil copper softer? does that get damaged any easier while on the road? thanks
photocodo
photocodo is offline   Reply With Quote
Old 10-10-2009, 10:10 AM   #20
Kevin245's Avatar
photocodo
The trunk line is actually steel. The feeders coming off the tee are copper. The advantge to the coil copper tubing is that it is softer then the hard pipe copper, and it does give should something strike it. Ours does have a few dings in it from years of towing, but there are no leaks.
Regards,
Kevin
Eleanor Roosevelt
LP Gas Lines Silverhobby All Argosy Trailers 6 01-24-2008 09:25 PM
Running propane lines Safari Tim LP Gas, Piping, Tanks & Regulators 7 07-01-2007 03:45 PM
Replacing Gas Lines? Frostyone LP Gas, Piping, Tanks & Regulators 2 05-14-2006 09:21 PM
gas lines scootertrash LP Gas, Piping, Tanks & Regulators 1 02-27-2003 10:00 AM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
