Old 07-06-2014, 10:24 AM   #1
1963 19' Globetrotter
Moline , Illinois
Rubber gas lines okay?
I recently read an article in RV magazine about replacing a refrigerator in a motor home and was surprised to see that the gas supply lines were rubber with factory crimped fittings going into a black pipe manifold system in the motor home "basement". All I have seen in trailers are copper lines and flared fittings other than at the tank to regulator lines . Are the rubber lines ok for the final hookup instead of copper? Sure would make replacing my next appliance easier.
63air is offline   Reply With Quote
Old 07-06-2014, 11:27 AM   #2
Images: 59
I've used rubber hose from the regulator to the main line, but a custom made, DOT qualified rubber gas hose is expensive.
Not a DIY project unless you work for a propane dealer.
Old 07-06-2014, 02:38 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Good old soft copper works good, flares easily, and readily available. The 3/8 OD, 1/4 ID copper tubing seems to thread through the tight spaces pretty good. It will bend to about 1 1/2 radius with a bender. I ran soft copper in my 66 without much difficulty.
David
Old 07-06-2014, 02:40 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I was up under a new SOB the other day, ALL of the LP lines are now rubber... FWIW back in the 70's and 80's the Airstreams were full copper on the LP lines.
Aaron
WBCCI #XXXX AIR #2495
Old 07-06-2014, 03:05 PM   #5
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
I' ve heard of folks inserting lp lines in rubber hoses to protect the copper from stones. Not sure I would just have a rubber hose. Doesn't sound safe.
Cyquest is offline   Reply With Quote
Old 07-06-2014, 04:07 PM   #6
joqin's Avatar
1965 17' Caravel
brooklyn park , Minnesota
rubber propane hoses
The squirrels chewed thru my rubber feed lines. I covered the new ones with automotive wiring covers and empty the lines when the trailer is not in use. squirrels will chew thru steel wool to get to a food source. they chewed thru an OSB shed door to get to my bird seed in steel can. joe q
joqin is offline   Reply With Quote
Old 07-06-2014, 04:55 PM   #7
Moline , Illinois
I've had rubber lines made at the propane dealer before and they were not that expensive especially when compared to the price of copper line now. I've got one I might have to replace that will be a real challenge to bend.
Old 07-07-2014, 03:49 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Crap! I forgot about that issue... I had a popup and was using a Mr Heater Buddy heater with the hose under the canvas to a bulk tank outside. Squirrels chewed up the line. I covered the new line with reinforced clear water hose.
Now you have me thinking about the rubber LP lines on the SOB... just one more thing to stay on top of.
Aaron
Old 07-07-2014, 04:39 PM   #9
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My outdoor grill has a rubber propane line. The squirrels chewed a hole in that line too. But only once in 10 years. Hydraulic lines have been rubber for years in HD construction equipment. I should think rubber hose in propane applications would be well developed. Kinda wish I had given some consideration to rubber instead of copper.
David
Old 07-09-2014, 02:14 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
This is a labor and therefore cost saving approach with lower quality than copper.
Copper will last 100 years. Rubber lines with propane inside... it depends. 10 years, maybe 20. The propane causes the rubber to degrade, so they use either a nylon barrier layer or much thicker rubber (so it takes longer to degrade all of it). Won't last "forever" either way.
Rodents, yes, a problem, usual answer is stainless steel overbraid although that costs money.
How to test gas pressure and bleed gas lines? maggieevans LP Gas, Piping, Tanks & Regulators 12 09-25-2013 06:02 AM
Rubber Gas Line Sundance LP Gas, Piping, Tanks & Regulators 4 07-13-2007 05:06 PM
gas lines scootertrash LP Gas, Piping, Tanks & Regulators 1 02-27-2003 10:00 AM
Squirrel Eating Gas Lines! lbrodsky LP Gas, Piping, Tanks & Regulators 8 07-06-2002 10:03 AM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
