Old 11-28-2008, 07:05 PM   #1
1975 Argosy 24
Williamsburg , Virginia
rotten egg smell when furnace is running
When the furnace is running a rotten egg smell is coming from the furnace. Is it a gas leak or a exhaust leak? How can I isolate where it's coming from? Is it possible to remove the furnace and serive it out of the trailer?
paul903 is offline   Reply With Quote
Old 11-28-2008, 07:34 PM   #2
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
I would shut that furnace off immediate and have it checked out tomorrow if possible. Are you in a campground with electricity available, if so a couple of ceramic heaters will do a good job until you can get the furnace fixed? I would also shut the tanks off as well.
63silver
63Silver is offline   Reply With Quote
Old 11-28-2008, 07:45 PM   #3
eubank's Avatar
1967 30' Sovereign
Bosque Farms , New Mexico
I agree absolutely! That rotten egg smell is probably mercaptan, a chemical added to propane to give it a distinctive odor.
Turn off all of your propane appliances (furnace, stove, water heater), and close the main valve from the propane cylinder(s). Don't use any of the appliances until you have the leak fixed.
Lynn
WBCCI 21043
Old 11-28-2008, 09:14 PM   #4
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
The furnaces I have seen in these campers tend to come out without a great deal of fuss. Definitely find the leak and keep the gas off. Good luck
94Tri is offline   Reply With Quote
Old 11-28-2008, 10:30 PM   #5
The furnace may have an LPG leak, or the burner may be out of adjustment, or it may need gaskets.
The combustion chamber may also have a hole in it, which means you would have to replace the furnace.
DO NOT under any circumstances, use your furnace again.
To be safe, it must be removed from the trailer, and taken apart on a bench, to find out the real problem.
Since the exact cause of the smell is not known at this time, you are dealing with a possible explosive hazard, until repairs are made.
Furnaces should be removed every 5 years or so, and bench examined.
Furnace - propane smell LI Pets Furnaces, Heaters, Fireplaces & Air Conditioning 13 03-11-2008 03:07 PM
LP smell at rear furnace Robfike LP Gas, Piping, Tanks & Regulators 5 12-06-2006 06:44 PM
Rotten egg / sulfur smell niss1679 Electrical - Systems, Generators, Batteries & Solar 17 10-17-2005 07:08 PM
That New Furnace Smell walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-15-2005 11:32 PM
Funny smell when running furnace yukionna Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-07-2004 03:03 PM
