Old 03-18-2010, 05:45 AM   #1
1978 28' Ambassador
Savannah , Georgia
Rod that holds tanks
Moved '78 AS and in the process the support rod broke at one of the holes where the roll pin goes. Wonder why there was a roll pin hole three inches above tongue weld? The rod was welded to AS. Have ground off old weld. Was hoping to thread the hole and screw in a new rod. Not an option. Threaded rod seems to be the concensus. Although alot of work was thinking about buying a solid hot dipped rod, thread the top and bottom, prime and paint. My reasoning was to reduce the chance for rust. Two things may prevent this from happening. The old rod had a roll pin and hole about ten inches down from the top. I now understand that this keeps the regulator from dropping all the way to the bottom when both tanks are removed. I also now understand why there was a second hole for another roll pin. This was for 20# tanks. Drill holes for replacement pins? Scrap this idea and use threaded rod and replace when it gets rusty?
Skamper1 is offline   Reply With Quote
Old 03-18-2010, 07:04 AM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Been there and done that. Here's a thread I started 4 years ago on this subject. Lots of responses with ideas to improve this design.
http://www.airforums.com/forums/f287...ted-20523.html
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-18-2010, 08:18 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The pins and holes ate pre-drilled for the different capacity (and height) tanks.
Old 03-18-2010, 09:42 AM   #4
1978 28' Ambassador
Savannah , Georgia
Had read your forum previously. Alot of good info. One of the reasons I removed the LP tanks before I moved the AS to my home. Found 1/2 inch stainless steel threaded rod at HD. ($9) Will check to see if threads match equipment. Should be able to attach alot quicker than welding and threading a new solid rod. Thanks. Jack
the rod that holds my tanks in place .... Rollerboy LP Gas, Piping, Tanks & Regulators 14 07-30-2009 04:15 AM
HHOT ROD / Lightning Rod ROBERTSUNRUS Water Heaters, Filters & Pumps 4 07-11-2009 05:03 PM
What holds up the bed?? frank n'shar Cabinets, Counter Tops & Furnishings 9 10-04-2007 08:10 PM
What holds up your patio lights? Cedars Community Polls 16 05-15-2005 03:47 PM
Hott Rod & Lightnin' Rod femuse Water Heaters, Filters & Pumps 6 09-22-2003 11:46 AM
