Old 09-19-2002, 05:52 PM   #15
Silver Bullet's Avatar
Smile
I just had one of my two 30# tanks changed, recertified and filled in El Paso, TX. Cost- $37.00. And I was lucky, most all distributors here are on a 1-1 1/2 yrs back order for 30# tank valves! Population and demand I reckin' Oscar
Silver Bullet is offline   Reply With Quote
Old 09-19-2002, 06:31 PM   #16
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
1 1/2 year backorder?????!!!
Yikes! I got one of my two done for $47, this spring including a fill up. Have not used up one tank yet this summer. Check out Flying J's prices for propane, nearest one to me charges $1.19 per gallon. If it gets cold this weekend I use some.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 09-19-2002, 07:13 PM   #17
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i have steel worthington 30 lb tanks, can't remember what it was a gallon (little over a buck it seems).
propane here is lower in the summer due to low demand.
john
Old 09-20-2002, 06:55 AM   #18
tomb's Avatar
Images: 8
TANKS
The old owner had replaced with new steel tanks...went back to him and got old alum tanks (he was about to throw away)..a had
new valves $15.00 dollors each ,installed for $10.00 each, and filled for $13.00 (30pd)...much happier with old tanks ...problem now ; i here the valves are getting hard to get and will get harder to get as cold weather gets here...so would not wait..just shop around..and if you need some incouragement..read that post someone had about his tanks coming loose and riding up under the trailer till one wore a hole in its side.....if they would have been steal....i dont want to think what would have happened..
TOM BOONE 1987 SOVEREIGN 25' WBCCI#14120
tomb is offline   Reply With Quote
Old 09-20-2002, 10:24 AM   #19
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
On 5-13-02 I posted that a place in LaVergne/Smyrna, TN. was replacing OPD valves for $10 each tank and this included testing along with a quick shot of paint if it needed it. Within a month the price increased to $12 then $15 each tank. I'd say it is higher than that now. I guess it is all about supply and demand. I still have one tank to have an OPD valve fitted but it is full right now. TN. is one of those states that has not complied with the regulation as of yet.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
New Propane Tanks... Sneakinup LP Gas, Piping, Tanks & Regulators 10 01-31-2004 05:15 PM
Propane Tanks: 30# or 40#? Navigator LP Gas, Piping, Tanks & Regulators 11 12-14-2003 03:08 PM
new or old propane tanks striker LP Gas, Piping, Tanks & Regulators 30 02-22-2003 02:32 PM
propane tanks david h Our Community 5 01-12-2003 07:49 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
