Old 07-15-2014, 04:03 AM   #1
Hiawassee , Georgia
Replacing water tank in 94 Excella 34
Has anyone had experience replacing the fresh water tank in this model?
JumpingJoe is offline   Reply With Quote
Old 07-15-2014, 07:05 AM   #2
1981 31' Excella II
New Market , Alabama
Is it leaking?
Perry
Old 07-15-2014, 08:38 AM   #3
Hiawassee , Georgia
A drip leak on the bottom. My initial thought is to first try a patch with marine-tex, which I have used previously on boats with success. I have priced a replacement tank, so that is another option. If someone has replaced a tank, knowing what to expect would be helpful.
Old 07-15-2014, 11:25 AM   #4
1981 31' Excella II
Is the leak from a crack or a loose fitting? There is a cleanout bung in the bottom of the tank that is prone to leak. I am trying to determine if the tank is the problem or not. With most tanks you remove the metal pan and it drops out. The problem occurs when the bolts holding the pan are frozen and they snap off when you try to remove them. The replacement tank needs to be exactly the same shape as the old tank which is unlikely unless you got the replacement tank from Airstream.
Perry
Old 08-07-2014, 05:48 AM   #5
1994 34' Excella
Kalamazoo , Michigan
We also have a 94/34. We had a cracked drain fitting on the tank, causing a slow drip. From looking at the tank, I think this is one likely cause, and much easier to fix. I would try to isolate the source if you can before taking the tank out.
TomS is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 02:32 PM
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
Replacing 1963 Safari black water tank flange?? christianMT Waste Systems, Tanks & Totes 0 05-30-2008 07:51 AM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
