Old 09-14-2006, 07:08 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Replacing tanks
These tanks appear to be oringinal, the local fill station says they have the old style valves and they would fill them or change the valves.
Said too old.
Is this true there's an age limit?
Anyway what size do they look like 30G?
I can but new 30's for $61 and 40's for $65 if needed.
'77 Sovereign Intl 31' CB
Old 09-14-2006, 07:18 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Said too old.
Yep, tanks now must have OPD valves they keep from overfilling the tank.
Tanks also need to have an inspection done every 11 or 12 years indicated by a date stamp. You can have your tanks updated with the new valves and tested at your local propane dealer. If they are steel it is cheaper to just buy new tanks.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 09-14-2006, 08:11 PM   #3
Larry71's Avatar
Allentown , New Jersey
Send a message via Yahoo to Larry71
I had the same problem when I first got our 71 Safari. The local propane dealer changed the valves, re-certified the tanks and filled them with propane for about $100. Mine were the aluminum tanks and I didn't want to go to a steel tank.
1971 Safari
2005 Nissan Titan
Larry71 is offline   Reply With Quote
Old 09-14-2006, 08:12 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Kinda figured that, if I buy 2 30's about how long would they last,
say in warm weather vs cold weather.
Or should I get 40's, for only a few bucks more,
the guy at LP gas center said the 30's will last all season I find that hard to believe.
Old 09-14-2006, 10:37 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It took me almost a year (3 camp days a month) to use 1/2 of a 30# tank. All boondocking with only a little use of a Cat heater. If you stick with 30# tanks you should not have to modify the mounting hardware or the propane lines.
Richard
Old 09-15-2006, 05:44 AM   #6
kramynot2000's Avatar
1978 31' Sovereign
Sacramento , California
Images: 20
I just got my tanks back
Picked up my aluminum tanks yesterday from Amerigas. Had them recertified and a new valve put on for $45 each and it took less than a week. These aluminum tanks seem significantly lighter than the steel tanks on my other trailer, which is nice when taking the tanks to get refilled.
Tony and Gale
1978 31' Sovereign International
kramynot2000 is offline   Reply With Quote
Old 09-15-2006, 08:06 AM   #7
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Kinda figured that, if I buy 2 30's about how long would they last, say in warm weather vs cold weather. ...
Or should I get 40's, for only a few bucks more, the guy at LP gas center said the 30's will last all season I find that hard to believe.
It all depends on how cold you mean! Up here, the ski-campers generally do about five days on two 30-lb tanks, but that's very, very extreme, not weather that I personally would ever camp in (around +20 during the day down to around -15 at night). In more temperate weather, you should be able to hold for a long, long time on two 30-lb tanks.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 09-15-2006, 08:20 AM   #8
ibgl6's Avatar
Southport (Panama City) , Florida
Send a message via AIM to ibgl6
Ouch Thats Cold...
Your Friend Sam In (Southport) Panama City Florida
Air#15607 TAC FL-2
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 09-15-2006, 08:30 AM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
Bob -- Are those steel or aluminum? See this thread and Janet's Husband's response.
5 meter Langford Nahanni
Old 09-15-2006, 09:36 AM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Originally Posted by ibgl6
Ouch Thats Cold...
Yeah, no poop. Folks who camp wintertime in this stuff with an RV ought to have their noggens examined, IMHO. More to the point of the thread, though, two 30-lb tanks should last a long, long time unless you're nuts enough to camp in extreme cold!
Lynn
WBCCI 21043
Old 09-15-2006, 03:56 PM   #11
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
They are steel.
Old 09-20-2006, 11:55 AM   #12
harestream's Avatar
1972 25' Tradewind
Nashville , Tennessee
Send a message via Yahoo to harestream
Thumbs up Where can you buy replacements?
I need to purchase either two new steel ones or two aluminium ones. I am leaning towards steel for now and may upgrade down the road to the nice lightweight aluminium ones. Locally I can get steel ones for 68 dollars each. This seems high to me. Any advice where I can purcahse these? And possibly drop off my old ones? I considered updating the ones I have already, but they have been painted over due to rust already, so I might as well buy new ones. Any tips are apprexiated. I live in Southern New Hampshire.
I've already tried calling Amerigas, Home Depot, Wamart, Blue Rhino, and Eastern and none of them could help me with 30 # sized tanks.
We beleive we aren't able to test out our furnace without more gas in our tanks. We've tried everything to turn on our furnace. So this got pushed up in prioirty with our renovation.
THANKS!!
-Kelly
"We are facing a movement of population beside which even the Crusades will seem like Sunday school picnics."
www.readysteadytow.blogspot.com
harestream is offline   Reply With Quote
Old 09-20-2006, 01:24 PM   #13
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
http://www.vintagetrailersupply.com/...ults.asp?Cat=1
I typically have to have a stove burner running in order to get the gas to flow enough to displace the air in the furnace's line.
once the pilot lights up, it takes a good 60 seconds of continuing to hold open the safety valve before the thermocouple heats up enough to keep the gas flowing.
you might want to pull that thing out and take it over to the RV place, and have them tune it up and bench test it. Its potentially a very dangerous device that you don't want to mess around with.
for testing purposes, you should be able to hook up any old tank for a gas grill...
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-20-2006, 01:39 PM   #14
harestream's Avatar
1972 25' Tradewind
Thanks chuck
I'll be sure to tell this to bill. Once we have these new propane tanks on, replaced our water heater, and know once and for all if the furnace works then we can shift our concentration back to the interior.. oh, i mean after we rervit and gasket the vista views too.. ugh...thanks for your tips.
-Kelly
Another reason for aluminum tanks rochleau Our Community 4 09-03-2002 06:30 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
