Old 08-24-2014, 08:15 PM   #1
1986 32' Excella
Dover , Delaware
Replacing pigtails on'86 32' excella
One of my propane connections has a leak so I'm going to replace both. Problem finding correct hose. The newer opd valves are installed and the hoses have been replaced at least once. They have the pol connectors and are about 36" long. I'm finding shorter(15-18 inch) & 60 inch ones which are too long. I've owned trailer for 15 yr. Not sure what the shortest hose is that will work. I have 30# alum bottles.
Suggestions?
rbhinzman is offline   Reply With Quote
Old 08-25-2014, 11:00 AM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Nearby home we have a place called " The Hose Shop". They will fabricate hoses of any length/ config. that you need. Check around and see if you have one nearby. They carry the couplings and fittings for hoses used in pretty much all industrial applications.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Marshall pigtails with 3/8" male fitting 2goldens LP Gas, Piping, Tanks & Regulators 4 04-03-2014 09:46 PM
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 02:32 PM
Need Quick Disconnect Battery Pigtails sharris1199 Batteries, Univolts, Converters & Inverters 9 08-05-2009 10:46 PM
Old 1/4" pigtails don't fit new 1/4" regulator? longdog LP Gas, Piping, Tanks & Regulators 1 04-22-2009 08:56 PM
Replacing couch with recliners in 30' Excella Ufatz Cabinets, Counter Tops & Furnishings 6 04-25-2004 05:48 AM
