Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-30-2014, 06:21 AM   #21
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Composting toilet
Here is a video about composting toilets in case anyone is interested:
Bob Martel
WBCCI# 5766
Old 10-01-2014, 10:37 PM   #22
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
When we get to our bathroom setup we are going for composting toilet for sure. We bought a black tank but will probably sell it now. The only thing I can think of that Andy might be saying is not to discard a black tank because some next person who gets it may inadvertently use it for fresh water tank?
Look up some of those composting toilets! You can make one for $5 for disaster preparedness or buy a beautiful ceramic one for your rig. Lots of options. Great for cabins with no plumbing etc.
No black tank!! Woohoo!!
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 10-02-2014, 04:55 AM   #23
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by cheetah1 View Post
Thank you to everyone for your responses! Has anyone ever replaced a tank in the back washroom (under the floor) and come up with a way to then access and be able to "service that tank" by dropping the belly pan in that area rather than having to pull the floor up if something goes wrong?
Don't think that's a good idea. The only way to service the tank from underneath is to put an inspection hatch in the belly pan, and a matching inspection hatch in the tank. But being on the bottom, as soon as you open the tank's inspection hatch, "Sploosh!" you dump the tank's contents out the inspection hatch— and in your face— rather than the drain valve where it's supposed to go.
You really need to access the tank from above for service unless the tank is bone dry.
Now, what you could do is put an inspection hatch in the floor alongside the toilet, so that you can access the top of the tank without removing floor or toilet, and a matching hatch in the top of the tank.
Old 10-02-2014, 04:58 AM   #24
Easy solution. Get a Sharpie marker in a contrasting color, and clearly label the tank "Non-potable (non-drinkable) water only!" on both top and bottom surfaces. Then you can sell it, discard it, whatever, without worry about the next person misusing it.
Old 10-02-2014, 05:18 AM   #25
1973 25' Tradewind
1962 22' Safari
Augusta , Georgia
Does anyone have any suggestions for a source for the grey water tank at a reasonable price?
look at eBay for potential grey water tanks. there are lots of abs (black hard plastic) tanks there. I found one that I purchased for $125 and fit it under the floor in my 1973. The tank specs listed were: "RV Holding Tank, 32"X5"X57", Mid Side Drain, 39 Gal Black/Gray Water, New, #218"
I made seller an offer cheaper than posted and offer was accepted. This one worked for my application.
Note that this approach takes some skills since I had to build a mounting system and configure the plumbing to the tank. You just have to decide what level of skill you have, set a goal just past that, and go for it. There is lots of good advice (and some not so good) available.
Good Luck
Dennis
DGJackson is offline   Reply With Quote
Old 10-02-2014, 05:26 AM   #26
1973 25' Tradewind
1962 22' Safari
Augusta , Georgia
ps - this system is accessed entirely from the underside, I just made the belly pan in that part separate from the rest. a second piece of aluminum 4-ft wide coves this bay. I installed with rivet nuts, but that's probably overkill. I've also been told I have CDO, that's an extreme form of OCD - only alphabetical like any sane person would organize it. for normal people pop rivets would work. good luck - dennis
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
VTS Vintage Grey Tank for Black Tank? bluemoontwo Waste Systems, Tanks & Totes 1 11-27-2012 08:03 AM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 06:47 PM
Grey/Black Water Tank Capacities BeBop Waste Systems, Tanks & Totes 3 06-18-2004 07:15 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
