Old 12-07-2006, 05:13 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Replacing all LP lines
Just wondering what I need?
I think it's type L copper tubing 1/2" main and 1/4" branched to each appliance??
Brass T's and what kind of flair fitting?
Are there any guide line to follow as to the layout or anything else I need to know?
'77 Sovereign Intl 31' CB
Old 12-07-2006, 05:33 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Bob,
When I get home I will attach a pdf of the gas line layout for you. IIRC it is 3/8" main and 1/4" to the appliances...or maybe not
Aaron
WBCCI #XXXX AIR #2495
Old 12-07-2006, 05:39 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Here is one suggestion!
Too many years working on old airplanes. I always look for something loose, something shiney or something loose. Then I fix it. The shiney one is important to the propane lines. When a copper line rubs against something like the frame or even the soft aluminum belly pan it will rub thru....then you have a BIG problem. Make sure the installation is chafe free. Loose and leaky stuff is self explanatory.
Old 12-07-2006, 05:43 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
The old lines had rubber inserts in small clamps just screwed into the belly pan in a hap hazard pattern.
What do the newer A/S have as line hangers?
Old 12-07-2006, 05:48 PM   #5
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
My tubing is 3/8 OD with a couple of 1/4" OD branches. You are correct using Type L copper. The sizing should all be referred to in OD (outside diameter). The valve should not be like the original. They should be ball valve type and marked with GSA? (gas)markings. You want to make sure you have a tubing bender and that you start with fresh shinny copper. Copper is malleable and each time it is bent it stiffens a little until it breaks. It also stiffens just sitting and aging. So you want to roll it out flat on a smooth flat surface then use your benders. Don't forget to put the nuts on before you flare the tubing! You will also find the nuts will not slide around a bend. You should look for valve with flared ends on both sides. Good luck Phil
Phil Gobie is offline   Reply With Quote
Old 12-07-2006, 05:52 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My 75 has a 5/8 inch main, not sure about the branches...
Richard
Old 12-07-2006, 08:18 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Plastic clips that will break faster Also you asked if there was anything else you should know...the current RV standard calls for a double flare on the end of the copper rather than the single. Here are the scans I promised.
Aaron
Old 12-08-2006, 09:44 AM   #8
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Hey Guys-
This is great information since I will be redoing LP lines in the spring on the '65 Tradewind. Keep the info flying! I'm taking notes.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
new water lines Rob Fresh Water Systems 29 07-11-2006 08:25 PM
Replacing plumbing lines GTracer Fresh Water Systems 1 06-29-2002 11:02 PM
Water lines in '73 Overlander Bryan Fresh Water Systems 8 06-05-2002 11:42 PM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
