Old 06-16-2016, 05:05 PM   #1
StreaminGeo's Avatar
2004 25' Safari
Hanford , California
Replace propane line?
The propane line from the driver side tank to the junction area just above the regulator has a leak where it screws into the tank (where the black line goes into the screw-in ring). Is this something I can replace myself?
StreaminGeo is offline   Reply With Quote
Old 06-16-2016, 06:15 PM   #2
r carl's Avatar
Lin , Ne
Of course, you will need it to match it up with a new one.
Old 06-16-2016, 07:02 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
It's easy. I just replaced both of mine. It only takes a few minutes to do. Make sure to get the correct type of pipe thread sealant, for LP gas.
Old 06-16-2016, 07:18 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
When I replacd the hoses, hard and soft, on my Bambi II I took them down to my local propane company. They duplicated all, including bending all the hard lines, for a very reasonable cost.
MICHAEL
Old 06-16-2016, 07:46 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Sure you can do it! Just get the proper propane line and fittings!
I did most of our line several years ago. Only to discover that the problem was our nearly new, USA-made regulator.
Lynn
WBCCI 21043
Old 06-16-2016, 11:07 PM   #6
2004 25' Safari
Good information, folks! Thanks!
Replace fixed shore line with removeable pickerdd Electrical - Systems, Generators, Batteries & Solar 3 10-12-2009 01:39 PM
Oil in propane line Deputych LP Gas, Piping, Tanks & Regulators 1 10-18-2004 06:26 AM
propane line under trailer? PodPeople All Argosy Trailers 7 08-21-2004 11:41 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
